1 - 3 of 3 Posts
Discussion Starter #1
http://cgi.ebay.com/ebaymotors...97801
Please let me know as he insists they will as the seller said this:
Hi,
Are you sure? It should be the same size as the GTi. The Front Disc is measured at 288mm (11.33") in diameter (vented disc). And the Rear Disc is measured at 232mm (9.13") in diameter (solid disc). These rotors are 5 lug bolt pattern. Check to see if the measurement is correct. Here's the correct listing for your vehicle: http://cgi.ebay.com/ebaymotors...97801
Please feel free to contact us with any other questions you may have.
Cheers,
V12 Motorsports
Re: Will these rotors fit my 337? (country_agent)
The 337 uses 12.3" vented front rotors and 10.1" vented rear rotors. Based on the description those are wrong.
Discussion Starter #3
Re: Will these rotors fit my 337? (NOVAdub)
Quote, originally posted by NOVAdub »
Thank you
1 - 3 of 3 Posts
