1 - 16 of 16 Posts
Hi,
I got this cluster the other day. The guy said that he removed ir from a 88 gti.
I haven't removed my cluster so I ignore if the conector are the same.
I readed about the CE1 and CE2, and I just noticed 2 types of clusters:
2 big harnesses and 1 harness.
The cluster I've got has 1 big and 1 small harnesses.
Will this work in my 87 jetta GX? My car has a clock, but no tach.
Re: (silverstallion)
Hell it'll fit. Even if it isn't a mk2 the shape will work with your dash. You may have to make modifications to the mounting points. You will also need to cross refrence the wires and then splice the plug and harness of the new cluster into your existing cluster wires. All possible if you have a Bentley Publishing manual.
Discussion Starter · #7 ·
Re: (Shaz8389)
thanks for the inputs.
very rare for me that hasn't clock, but it was cheap.
I'm not sure if it worth to change rpms x clock, but my cluster has white gauges and I don't like it any more...
may be possible to move the clock to the new cluster?
thanks again
Banned
Re: will this cluster work in a jetta 87? (silverstallion)
...why post when you dont know what your talking about?? This is what makes vortex so frustrating for people.
It is not a ce1 cluster. This is a ce1 cluster
Discussion Starter · #10 ·
I found this pics in the net, mine is the same:
the other:
I called again the guy who sold me this, and he says it was in a GTI 88-89. They look different...
Modified by silverstallion at 6:37 PM 2-2-2010
Discussion Starter · #12 ·
well, as I see it now, I got a rare (wiring) and useless cluster for my car.
Maybe doesn't worth the re-wiring job.
Thanks a lot for your attention, I will look for another one
edit:
re thinking this, I will try to make it work. To get a CE1 cluster is around $90 USD in my ranch.
any useful wiring diagrams?
Modified by silverstallion at 11:31 AM 2-3-2010
Quote, originally posted by silverstallion »
please?
Quote, originally posted by gtifly »
Hell it'll fit. Even if it isn't a mk2 the shape will work with your dash. You may have to make modifications ... All possible if you have a Bentley Publishing manual.
http://www.partsgeek.com/mmpar....html
There's your diagrams. Or try looking at the online ETKA at vagcat.com
Modified by HagbardCeline at 2:56 PM 2-3-2010
Re: (HagbardCeline)
Yea just go ahead get a bentley, it will help you for this and literally everything else your looking to do, its like 30 bucks on amazon or you can probably find it cheaper from someone on here
Discussion Starter · #16 ·
Re: (semaj4712)
thank you, I was just wondering if it was avaliable online. Remember I'm way south.
I'll search at vagcat.com and will look for the bentley.
Modified by silverstallion at 5:59 PM 2-3-2010
1 - 16 of 16 Posts
