1 - 2 of 2 Posts
Discussion Starter #1
wind noise comes from driver side window and wing mirror when the speed is above 60mph on my 2014 A6 C7 avant its like a whistling noise, had the doors seals changed, wing mirror seal and gromit but no change can anyone help pls
I have a 2015 A6 sedan and have this issue sometimes. I believe it's the airflow around the mirrors.
I'm curious if you could "safely" troubleshoot things by folding in your mirrors (some models have the mirror adjustment switch you can turn 180 degrees to fold in the mirrors while in park) then drive 60 and see if that get rid of the original wind noise. Although I'm sure this would cause a different wind noise issue.
1 - 2 of 2 Posts
