This thread may end up with a lot of flack over my sound system installation, but irregardless I need to find a solution for where I’m at. I chose 6.5 speakers because I only wanted to run the fronts.
I installed two 6.5 inch speakers within door pods to my two front doors on my ‘76. I placed them where I would get the most crank clearance possible, but still knew what I was getting into and accepted that it wouldn’t be sufficient. I need either two door cranks (with the proper splined + screw hole fitment), that are significantly shorter than the stock, I need my stock cranks modified by someone that has the ability, or (most preferable), I need intel on how I could potentially have button controlled motorized devices to connect over the splines and spin either left or right to roll the windows. It may sound outlandish but it’s a very simple engineering concept I’m certain I could have done, top dollar or not. I just need someone to point me in the right direction.
If you have input on any of my three options (or other ideas), your thoughts will be greatly appreciated. The stock cranks are only 1.5 inches too long.
thanks
thanks
