Windshield wipers only working on "high"
33K views 16 replies 12 participants last post by  LG6R
#1 ·
A few weeks ago i got in a front end accident and one thing leads to another i had to disconnect my alarm module. Ever since i took it out and put it back in the windshield wipers have only worked on high speed. I'm guessing it's related to this because of the fact that they go off with the alarm so if anyone could give me some insight on this that'd be great. Thanks in advance:thumbup:
#4 ·
id like to know too mine aren't working besides on high speed. i have a feeling it has to do with the ignition switch, i know it sounds weird but my car wont start all the time but i can jump the starter so i looked up symptoms and i have read of symptoms like the wipers not working right... so more info please.
#7 ·
going to mess around w/ it today after i replace my starter:rolleyes:
#9 ·
Can't be the ignition switch. Do the wipers work in a car when the key's not turned? No.
It's the wiper relay. Depending on what year the car is, it could be the relay that says either 99, 19, or 196.
And anyone can test this. Take out the wiper relay and you'll get the same thing, the wipers will only work on high speed. It's either loose and will need to be plugged back in, or it's defective and needs to be replaced.
#13 ·
usually people dont do that for no reason, but maybe not. hopefully it wasnt cause it was blowin fuses or somethin. but it just sounds like the PO did it for no reason, hope it works out bro.
i will have to chck mine too.
#17 ·
awesome thanks for the response!
But if I dont go programmable (what exactly is the benefit, btw?) I would use a 19 relay, correct?
and while we are talking relay's, can I just remove the number 9 relay, and lose the door chime?
Programmable (99) = you can program the intermittent wipers to wipe between 1.5 seconds and 22 seconds, depending on condition and how often YOU want it to wipe. I use mine more than the low setting, it's my favorite feature of the car
Non-programmable (19, 196) = it wipes every 6 seconds. Really annoying if it's a very light drizzle or a heavy drizzle
Shameless plug... I have them for sale :p
