1989 Jetta 8v.
I picked this car up from a friend of mine for free while I take my VR Coupe apart this winter for the goodies i'm buying for it.. It was his daily beater while he was building his 16vT SyncRado.....
It had a few issues needed TLC that had to be sorted out and i Took care of them. Theres a few left that have me stumped....
--cold start issue.....The car doesnt idle on its own when its cold. It starts up and idles REALLY rough around 500-700, and if I dont hold the gas down a little, it will die. Once its warm it holds idle fine and starts fine. Coolant temp sensor????3
---I found a sensor that had a messed up wire at the plug. I believe its the TPS. It goes to a plug at the throttle body, which leads to a small microswitch UNDER the TB. What does this control/monitor?
--I also have the ground strap that comes off the valve cover not bolted up. I have to get a new one....Do these ground mods floating around really help out for an 8v ?
I'm not really too worried about this car...Its my winter beater anyway, But I commute about 30 miles to school and 30 back..and Need it to be somewhat reliable and not leave me stranded in the lot because it doesn't start.
Any help is appreciated. Thanks! http://****************.com/smile/emthup.gif
