1 - 11 of 11 Posts
Is this feature on the Gli. I followed instructions in manual: turn ignition on momentarily and push down on wiper control. All this does is move the blades to vertical. Easier for changing but I would like to move them out to keep the blades from freezing to the glass.
Re: winter position on wipers (shadydevil)
Quote, originally posted by shadydevil »
You answered your own question. When they're in the "service position" you can pull them off the glass and leave them there. Just don't start the car with them left there, or they'll forcefully go back down hitting the edge of the hood.
Re: winter position on wipers (VWYankee)
Since there was no pictures I had figured that in concealed position the blades would pop a 1/2 inch off the glass by themselves. So it is a mnual function. thanks for replying.
Re: winter position on wipers (jetta v)
Quote, originally posted by jetta v »
no, you can start the car with them up just don't push the the switch with them up after starting the car. the switch is what reactivates them, not starting the car.
It may be different settings in different cars, but I'm certain it happens on ours after about 5 seconds of the car being ON.
Quote, originally posted by VWYankee »
I dont know about all mkV's but I have a 06 GLI and my wife has a 05.5 2.5 and both cars can be turned on with it in service and only when you turn on the wipers again does it go back down. maybe its vag-com option to go out of service mode when car turns on?
Re: (fr3sh)
Quote, originally posted by fr3sh »
I have an 06 2.5 Jetta and use the wiper service mode all the time. My whipers do not go back to their original position until the vehicle is moving or the wipers are turned on.
Just realized I left out a little smidge of info. I was cleaning the car, so I moved it 10ft, and they came crashing down.
Re: (VWYankee)
now it makes sense, good to know that I cant move the car if wipers are up.
1 - 11 of 11 Posts
