1 - 8 of 8 Posts
on the 42 pin connector right behind the coilpack on a obd2 vr, the number 2 wire was cut somehow and its too short to connect back.. wahts is # 2. does anyone have a diagram or chart showing all 42 pins.. also can i jus cut the other end and put a male a female connectors on each and just connect them that way??
Re: Wire harness help.. (jok3sta)
Is the color of the wire White with a blue stripe?
This wire goes to the middle pin at the transmission VSS.
Discussion Starter · #6 ·
Re: Wire harness help.. (Eric D)
yah its the blue and white wire goin to the tranny.. can i connect the 2 wires straight up w/o beign in the connector?
You can get the proper pins from the dealer, and add a short extension (soldered and heat shrinked, or the bulky butt connector).
If you do decide you want to bypass the big round plug, then use matching male and female connectors. This will allow you to still service the vehicle and allow for easy disassembly.
1 - 8 of 8 Posts
