I did a search and can't find an answer to my specific problem. I have a 2022 Tiguan SE R-line Black for the last couple months. When I first got the vehicle and set everything up the Android Auto worked wirelessly without any problems, about a month into owning it I did the trial subscription for the wi-fi hotspot. It worked well for a while then I realized the trial was only good for 1gb of data and I went through that quickly since I stream music from Pandora and use the maps for traffic data on my long drives to work. After I reached that 1gb it was always saying the maps and streaming music were in offline mode. The wi-fi trial was through Verizon and my cell phone is a Samsung Galaxy Note 9 that uses AT&T FirstNet for service.
I called VW in the car and they said they couldn't help but gave my some type id number to give to Verizon. They connected me to an operator there and Verizon said they have no record associated with the id number I gave them. At this point I was getting the feeling that I would have to do a factory reset on the head unit. I uninstalled the CarNet and Android Auto apps from my phone then did the factory reset to the head unit. Started going back thru and doing all the set up used the QR code method and the start up wizard everything seemed to go back to previous working order. Tried to start up Android Auto and was told the phone had to be connected via the usb to set it up. I did that and went thru the process and now can only use it while its connected via usb. I have the wi-fi turned off in the head unit and when I turn it back on it still will not let me use anything wirelessly. When I disconnect from the usb my phone shows a bar that says its searching for Android auto and quickly drains the phones battery. I shut off the wifi again and still get the same results.
Is there something I am doing wrong or do I need to take it to the dealer and have them look at it? Any help is appreciated!! This is one of the more technologically advanced VW's that I have ever owned and it's very frustrating to try and figure it all out but I love this car and is probably my favorite one I have owned so far.
