Re: Wiring: Constant, Ground, & Switched behind NAV Radio (spockcat)
Sorry, my firewall seems to have an issue with the IM stuff --
I'm already tapping into the fusebox for my audivox PNP -- I'm looking at buying a different unit (XM Commander) and I'm not sure the wires will be long enough to run to the fuse box ... I ran into this problem when I tried to install a Panasonic SAT tuner.
Since I have to plug the audio from the commander's tuner into the the NAV using your AV adapter, I thought I would just install the XM Commander behind the radio.
Does this make sense?
