1 - 5 of 5 Posts
I'm trying to wire up my boost/oil temp/oil press gauges for light, and when I turn the lights on, w/o starting the car, only the left and most of the time the middle gauges light up. If I move the wires around on the back, the middle one will cut in and out. The third one never lights up, so I checked the back with a multi meter, and there's voltage there.
When I turn on the lights with the engine running, only the left one comes on, and I get a solid warning tone from my car.
Any help please?
Modified by allstarmaterial at 9:25 AM 2-15-2004
Pop the LED holder out from the back of the gauge, and push down on the LED to set it in place. I know mine were pretty finicky about being pressed all the way in, and easily slid out if rubbed or touched when you put them back into the gauge.
Discussion Starter · #4 ·
Re: (Alex M)
Quote, originally posted by Alex M »
Ok, that kinda worked. The LED was in upside down. Next question:
I tapped into the light dimmer switch and ground for power/ground. I used the little foldover inline wire taps. I think this isn't a good connection because the power to the lights is intermittant. What is a good/better place or way to tap into power and ground, or should I put my ground to the chassis?
1 - 5 of 5 Posts
