Wooosh! NOS
799 Views 14 Replies 6 Participants Last post by  vce123
Has anyone used NOS on their VR6/2.l ? If so what precautions did you take?
See less See more
1 - 15 of 15 Posts
Re: Wooosh! NOS (HT WTR)
Yes I have...depends on what power shot you use....
See less See more
Re: Wooosh! NOS (vce123)
Just a 50 shot
See less See more
No mods needed.Make sure that its set up correctely with a bottle warmer and your all set...You need to fill out a card when you refill the puppy...They wont sell it to you with out it...Use premium gas when using the system..I dont recomend this on automatics.The trany is pretty weak as is...NOt designed to hold that much power at a burst....My opinion....
See less See more
god, this makes me want to add naws.
Will it wear out the engine much faster than say a port and polish, big cams and exhaust etc?
See less See more
Re: Wooosh! NOS (B3_Golde)
In theory NOS won't wear the engine down any faster than a ver, very mild forced induction system. You see, all NOS does is add more air, and more fuel into the combustion chamber to give you more horsepower. A turbo or supercharger does the same thing. It really doesn't come down to what you add to the engine that promotes engine life. It's your right foot. I'm building a direct port 100 shot wet set-up to the VR6 just for giggles, and when correctly built, can deliver HP with very, very little if any decrease in engine life. (no shorter life than adding a turbo or supercharger). NOS is actually safe and dependable...it's all the idiots that don't know how to build the system and run thier engines lean and melt pistons that give it a bad rap.
Re: Wooosh! NOS (Soviet B3)
Agree,I had a fogger Nozzle set up on my 16v,knock on wood never had a problem and it was a 75 hp set up...I did a compression test on it just for fun and was all with in specs after a year of juicing it up....lol
See less See more
Is wet safer than a dry system?
See less See more
I'm purely not interested at all in putting nitrous oxide in my passat, but i am curious as to how much a bottle would cost, and how many shots it will last for.
4
Hmmm, having read the posts thus far, it appears that only a couple of people have installed a bottle in their passats, I'm sorry if this is redundant, but how many have done this with their Passat VR6's? I am going to install NOS into my 2.0L 8v Rabbit, probably a 50 shot, but then that car is only a weekend driver at best, the B3 we drive daily. Is this true that NOS can used regularly? What kind of extra maintenance is required? Any Passat running NOS I think would be cool, I have these visions of my wife spanking some kid & his mustang while driving my son to basketball practice, hehe...
[Modified by demonGTI, 9:38 PM 2-6-2002]
See less See more
Re: Wooosh! NOS (N'Syncro)
Sneak and peak bottles will last about 2 passes down the track and a full size bottle will last about 25 passes,pending on how its used...
See less See more
2
How much would each of those bottle cost you??
I was always under the impression that even that small 2 pass bottle would cost like $50-$100usd.
See less See more
A new kit with a 10lb bottle ( stage one) will cost $499 - $650 and you still have to install it. The smaller bottles cost just as much as the big ones.
See less See more
How much to refill a bottle though?
The purpose of a sneak and peak bottle it to conceal it so no one knows that you are squirting them..Theta way the price is the same and its way smaller...The juice system is still cheaper then adding a turbo by far....
See less See more
1 - 15 of 15 Posts
