1 - 13 of 13 Posts
Re: WOT voltage on jetta 1.8t (02'jetta)
Call Adrenalin up to ask for details. If you click under products, you would be able to see the nitrous kit plate and mounting scheme they used for the audi. Same for your Jetta.
I drove their Audi with 75 NOS. It does put out 75 hp at the wheels as the dyno sheet showed.
And trust me on the 0V.
Discussion Starter · #9 ·
k, got my tps switch today from nx. It says that it is only for use with 4. volt or higher @ WOT cars. You say WOT is 0 volts.
The guy I ordered from knew what kind of car I had. So will this switch not work????
PLUS
Where do I find the TPS on our cars? And which wire is the output signal to the computer??
Please help I need to install this asap...wanna have fun this weekend
THX
[Modified by 02'jetta, 4:23 AM 12-5-2001]
Re: WOT voltage on jetta 1.8t (TypeR202)
ECU pin 35 is the pedal. ECU pin 108 is a ground. Not sure on the voltage I would assume that no gas ~0V, WOT >3.5V, but I haven't DVM'ed it.
I see you have a 2002, so better check with a DVM!
-Scott
[Modified by scotty_passat, 8:21 AM 12-5-2001]
1 - 13 of 13 Posts
