1 - 6 of 6 Posts
my motor kinda runs like its off one tooth timing wise. it has kinda sucky low end but screams over 4k. so im wondering if the cam position sensor would notice this and throw a code. thanks
Re: would a code for off timing show up on an OBD2 vr6 (rocket vr6)
the car isnt misfiring though, my suspicion is that the timing is off ever so slightly.
Banned
Re: would a code for off timing show up on an OBD2 vr6 (JNXtheband)
Well if the timing is off it might show up as a missfire. If it's idling really rough. Check for presence of codes, it may not necessarily set of the CEL.
Quote, originally posted by JNXtheband »
Yes, if the crankshaft, camshaft, and ignition firing do not "line up", you will see a CEL.
The ECU will scream at you about a camshaft position 'out of range', etc.
There's no negative mechanic noise or grinding of the sort, right? How sluggish is the acceleration?
Done any tune-up procedures lately?
- Erik
Discussion Starter · #6 ·
Re: would a code for off timing show up on an OBD2 vr6 (bluefox280)
no negative noises. my check is always on since i pulled the airpump out though.
I just did my timing chains since i noticed this problem so thats another reason i suspected it. Im gonna vag com it tommorow.
1 - 6 of 6 Posts
