1 - 5 of 5 Posts
Discussion Starter #1
yeah, will it? i just wondered if this would http://****************.com/smile/emthup.gif
Re: would a vr cluster work in a 2.0? (JonnyBoy-17)
itll fit, as for working...i think the RPM, and MPH/KPH wont read the same if i remember correctly...
Re: would a vr cluster work in a 2.0? (snuffyboy3)
Speedo reads correct, but the tach will be a few thousand off. Momentum sells modules to correct that.
Discussion Starter #4
Re: would a vr cluster work in a 2.0? (Greg.The.Bunny)
quote:[HR][/HR]Speedo reads correct, but the tach will be a few thousand off. Momentum sells modules to correct that. [HR][/HR]​
thats what i figured, do you know how much they sell for? i never saw em on there
i had a 2slow cluster on my vr ,it works fine but the only problem is when you shift the rpms go crazy,when you usually shift at bout 3000 rpm the 2slow one is at like 4000 rpm or 4500rpm,its gets high fast, the mph is the same,i check on one the police machines that tell you how fast ur going.....just my 2 cents
1 - 5 of 5 Posts
