1 - 5 of 5 Posts
Or will modifications need to be done to the rim for it to fit? I know the TT rims will fit since they are as well 5-100. Any help is appreciated...
Ollie
Banned
Re: Would audi rims (5-112) fit a GTI (5-100)?? (Ollie18)
if you wanna run 5X112's you ll need adapters but if you use adapters then your wheels might stick out too far........if you really wanna run audi rims keep it simple for yourself and just get the tt's
Re: Would audi rims (veedubpwr)
Ok - that's what I thought. Thanks alot for the help. I might just get some TTs. Got a deal on hand, they will need some work, but the price is unbelieveable...Thanks for the heads up though..
ollie
Some Audi's use a higher offset than others. A8 and S4 wheels are typically 45mm or so. Those will work fine with adapters. Most Audi's use 35-38mm though, which would still work, but not as well.
1 - 5 of 5 Posts
