WRD Advantage Coilovers provide a perfect balance between comfort and performance. With threaded shock body's and perches they allows you to adjust the springs to give your VW or Audi the ride height you desire, lowering the center of gravity and increasing the performance and handling.
WRD Advantage Street
MK5 Rabbit/GTI/Jetta
Retail: $499.95
$399.95 SHIPPED within the continental United States
CLICK HERE TO ORDER!!!
WRD Advantage Street+
R32/R/Jetta Sportwagen/Passat/CC/A3 Quattro/TT MKII Quattro
WRD Street+ Coilovers have upgraded springs manufactured in Germany utilizing the highest quality German alloy steel. This provides a significantly improved ride quality over all kits in it's category.
Retail: $599.95
$429.95 Shipped within the continental United States
Product Features
Lowering Range: 35mm to 70mm*
Warranty: 3 Year limited warranty**
Ride height adjustability for a more attractive stance and look
Reduces body roll and lower center of gravity for improve handling
Shocks valved to match our performance spring rates
Chrome finish for corrosion protection and a show quality appearance
Black powder coated springs
Black anodized billet aluminum hardware
Front Axle - Maximum Lowering (12 3/8 from center hub to fender)
Rear Axle - Maximum Lowering (11 7/16 from center hub to fender)
* Lowering ranges varying depending on vehicle modal and condition
** Professional installation recommended
Kit Includes
Two front threaded coilovers, chrome plated for corrosion protection and a show quality appearance with twin tube low pressure gas shocks insides.
Two front spring perches and locking rings hardware, anodized black.
Two front springs and two helper springs, powder coated black.
Two front shortened sway bar end links.
Two rear sport shocks matched to the springs and lowering range, black.
Two rear billet aluminum adjustable threaded spring perches, black anodized.
Two rear progressive rate springs, powder coated black.
Two coilover adjuster wrenches
An Example on one of our customers cars, lowered fully front and rear
How low these go, front and rear
Retail: $499.95
Retail: $599.95
Product Features
Kit Includes
