1 - 6 of 6 Posts
Thanks for the replies. I found something that works. I needed the cable for an 02A/02J swap into a MK1 Rabbit truck. I found out that the cable from a Eurovan is a two peice and that the lower half fits the trans. The upper half from the early Rabbit screws on to the lower half. So now the Rabbit speedo works. Maybe you all knew that. I'm sure the ratio is not even close, but at least it something.
1 - 6 of 6 Posts
