sorry forgot the OBD1 system is called Motronic M2.9 (M2.9.1 for engines with coil pack), and OBD2 is called Motronic M5.9.
Okay so,
I have done about 3hrs. of research and a friend has also helped out. And we came up with this.
DOW CORNING MOLYKOTE 321.
This is used by FORD and Mitsubishi on their throttle bodies. They say to never clean them! If you do clean them, then you need to reapply this stuff to the butterfly/bore. Let it dry and crack open the butterfly, adjust your idle stop screw. Enjoy your low idle setting.
I will install the manifold in the morning along with the new phenolic spacer. (helps keep the fuel rail cool) I bet with the stop screw out all the way, it wont start. Screw in the stop screw until it idles.
:beer::thumbup::beer:
After allowing the MOLYKOTE 321 to dry over night. I slowly cracked open the butterflies to break the now all closed position with the idle screw out. It started right up and is idling at around 850-1000 rpms. I didn't have much other time to play with the MS tuning today, but will in the morning. Made a dyno appointment and I will report back then.
"candm" came by today with the TWM 16V mani's. And they look really nice and simple. Now I'm starting to mock up a set up in a rabbit.
Did you read the previous replies? Sounds like he had air leaking past the butterflies and used the DOW CORNING MOLYKOTE to make the butterflies seal better.so how you fixed you idle problem ??
Okay so,
