Will a g60 fuel rail work on a xflow intake manifold? Or do you use a xflow fuel rail with digi injectors? If you are using the xflow fuelrail will the g60 fuel pressure regulator work with the xflow fuelrail. Or can you use the the xflow fpr with digi 1? Thanks
