So, the other night we're putting new injector o-rings & bushings into the 1.8 16V in my friend's '81 Rabbit (normal '87 Scirocco electronics), and like an idiot I let the tip of an injector contact the 12V post on the alternator. Zzzzzapp! Large blue arc. After we come back from heading for the hills, it looks like nothing's wrong, but now the car runs... oddly. You have to feather the throttle or it wants to bog, and it seems to be running generally too rich. It seems to match the behavior described in the Bentley as a problem with the Differential Pressure Regulator, but that thing seems to pass the test laid out in the Bentley just fine. What else should we check? Did we maybe fry the airflow plate potentiometer? Help!
Oh yes, thanks in advance for any help, and the admonitions that I should have disconnected the battery. I know.
