zender wing spoiler question?
611 Views 8 Replies 4 Participants Last post by  wacktool
I bought a zender spoiler for the jetta. It was previously attatched, and was removed from a fellow vortexer. Does anyone know what I can use to reattatch it?
1 - 9 of 9 Posts
Re: zender wing spoiler question? (jettanjax)
ttt
bumpity bump
bump
I assume you can just sand it down and then glue it on.
Speaking of Zender spoiler installs, does anyone have the link for an install guide?
Re: zender wing spoiler question? (Jeff Andrews)
quote:[HR][/HR]I assume you can just sand it down and then glue it on.
Speaking of Zender spoiler installs, does anyone have the link for an install guide?[HR][/HR]​
Thanks for chiming in Jeff. Just sand the underneath of the zender or the sand the trunk? yah, a install guide would be helpfully
Just to chime in before i leave for class.
The lip itself has a layer of black caulk on the bottom of it. It will come off with some scraping. Before you glue it on, be sure to clean the area with some rubbing alcohol to remove any wax. I am thinking you could use some industrial strength adhesive from home depot. That is all this is.
Here is a link I have saved for when I do the Zender purchase. Hope it helps. Not sure if you really wanna do it like this, but if it saves you the cost of having a professional do it, and it works...go for it!
http://www.haleyinsurance.com/matta...ender/install/installing_zender_rear_wing.htm
Re: zender wing spoiler question? (The Shadow)
thanx
1 - 9 of 9 Posts
