1 - 16 of 16 Posts
jazzyjazz
Putting in a new motor in my 02 Jetta 1.8T, anyone know of any removal walkthroughs? ive got the front clip off already
replaced the rad
i have a new clutch, new flywheel, new water pump and timing belt for it, new motor, any kind of walkthrough would be nice
sorry about the iphone pictures
replaced the rad
You want a walkthrough now? You're in over your head if that's the case. Good luck.
How to remove ANY engine:
Disconnect battery
Disconnect fuel supply
Disconnect and drain coolant system
Unbolt exhaust from manifold
Disconect all electrical/vaccum/intake connections
Unbolt drivetrain components
Support the engine with a jack or hoist for removal
Unbolt all engine/transmission mount
Remove engine
funny how many people here say that, but are here looking for help... Weird.
Which is why i don't go to the dealership for repairs... Small reputable shops are the way to go :thumbup:
No offence meant towards the OP, just makin a general comment.
Looks like you got it taken care of and you didn't really need any tips. I know your working at a Ford dealer but cars are cars. They all have the same stuff (fuel pumps, radiators, exhaust, ect) it may just look different or be in a different location but it's all still there for the most part. That's just a generalized statement but if you can process that it will make you a better mechanic overall.:thumbup:
Discussion starter · #15 ·
See. Wasn't that hard.
no no you guys are right, i just figured knowing sort of what i was up against would help, i was really hoping for things to look out for and things to make sure i look at while its out, but i got that, with the new motor i put on a new single mass clutch, a new timing belt and water pump with a metal impellar, the new rad is in the front clip already, i have a new K04 turbo with software coming and i will flash the car, (i made some friends at school who work at a Beemer dealership and can get me a nice hookup) :laugh: and i have some new suspension to go in might aswell get that in while she is uo there
1 - 16 of 16 Posts
