2011 VW CC 6 Speed, Trans issue?
2.5K views 8 replies 5 participants last post by  RSmass
#1 ·
Hello, I got a 2011 Volkswagen CC 6 speed manual 2.0T that has a weird issue with the manual trans, 1st gear is impossible to find unless you go to 2nd first then 1st, 5 and 6 sound a little "sticky" and gear shifter sticks wherever you place it. I have uploaded a video to show the signs, if anyone knows whats wrong with it please let me know. little thing to be noted here. I bought the car like this (from a auction) so I don't know how long its been going on or any history behind it, its a nice car and would like to keep it, but not sure what the issue is. here is the video, any helps is appreciated.
#4 ·
Also, check the alignment in the interior shifter box as well.
There is an alignment hole on the shifter box assembly under the shift boot.
All you need to align it is a nail or small straight pin to align things.
#7 ·
I stated I don't know the history, im a dealer. Bought it from a auction. No signs of wrecks. Pretty sure it just needs grease. Probably not an alignment, haven't had time to grease it yet about to do it tomorrow. It shifts fine sometimes. Usually when it's bone cold. When it heats up it starts to act up until its bone cold again.
#8 ·
If it all checks out, look at the engine bushings. I have a lot of slop in my rear bushing and am going to get it replaced. Because there are times after I park the car, it doesn't want to go into first and needs the 2nd to 1st shift to get into 1st. It happens are random plus the shifting of the engine mounts makes me think it could be that in my case.
