ACC coding???
43K views 20 replies 8 participants last post by  2017jet
#1 ·
Dont get why I get this code, no cel, ACC works... any clue?
Address 13: Auto Dist. Reg Labels: 3Q0-907-572.clb
Control Module Part Number: 5Q0 907 572 G HW: 5Q0 907 572 G
Component and/or Version: ACC BOSCH MQB H10 0571
Software Coding: 350000C151FFC428949C8045000016
Work Shop Code: WSC 01357 011 00200
ASAM Dataset: EV_ACCBOSCHVW416 001005 (VW37)
ROD: EV_ACCBOSCHVW416_001_VW37.rod
VCID: 3B750E67B2EAE09E9F-806E
1 Fault Found:
0836 - Databus
U1123 00 [008] - Received Error Message
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 6
Fault Frequency: 254
Reset counter: 170
Mileage: 11387 km
Date: 2017.09.15
Time: 11:52:32
Dynamic environmental data: 02 8D
Control Module temperature: 48 °C
Voltage terminal 15: 13.5 V
Velocity_vehicle_reference: 1.11 m/s
Longitudinal_acceleration_vehicle_reference: 0.67 m/s²
Status_ACC_System: ACC_Off_MainSwitch_Off
#2 ·
1 Fault Found:
0836 - Databus
U1123 00 [008] - Received Error Message Intermittent
I received a similar error message multiple times, and on the dash it would pop up saying "ACC not available" for 5-10 seconds if it happens in use, and then it would go back to functioning perfectly like nothing happened. Same error code as you U1123
Code:
13 Adaptive Cruise Control
   System description: ACC BOSCH MQB
    Software number: 5Q0907572G
    Software version: 0571
    Hardware number: 5Q0907572G
    Hardware version: H10
    ODX name: EV_ACCBOSCHVW416
    ODX version: 001005
    Long coding: 350000C151FFC428949C8045000006
   Trouble codes:
        U112300 - Databus error value received
            Intermittent
        U112100 - Databus missing message
            Intermittent
Brought it to dealer and they scanned and cleared the code, told me if it happens again they'd have to bring in a tech. It comes up for me approx once a week, sometimes every day, sometimes i'll go a month without it. I leave ACC on all the time (in an inactive state) so i notice it every time it comes on. They said their tech actually just got back from a VW learning seminar on this exact issue and would have to bring someone specific in to look at it. They said before my car they've never seen this issue before.
I dropped my car off yesterday and they said they'd have an update for me tomorrow, so i'll let you know. Didn't sound good the service guy i spoke to is assuming he'll have to order parts but when i learn anything ill let you know.
#4 · (Edited)
Thanks, please keep us informed.
Funny, my car was in the shop for a lane assist error, they had it over a day on the machine to get the lane assist cam aligned using a special machine (part headlight dot board part another board underneath).
I don't think they replaced any parts. After they fixed it, I happed to scan the car for codes a couple of times. But, this came up a couple of weeks later (after adding the 8" screen), with a crazy amount of frequency.
I will keep scanning the car and see if I can figure what triggers it and if any other codes or issues occur.
Doubt I will be much of any help though, other than taking it BACK to the dealer if/when the code comes back, which I really don't want to do, because the only VW dealership that has the complete machine of the 3 dealers, is one I can really live without.
Edit: I was asked by a VW tech, didn't you change out your wheels or have a TPMS icon. He said that usually occurs when one of the two occurs.
#3 ·
I am glad you asked. I get it too and not sure why. There isn't much to google on it either.
One thing I have noticed, but cannot pin point with certainty is that it seems to come up less often since I set my XDS+ back to normal from strong. Also seem to comes up less if I drive normal rather than hooning around.
I once heard that if ACC engages, the ECU can trigger a code as it notices a drivetrain issue. Don't recall where I read it or how accurate that may be, but these cars are quite complex so who knows.
#8 ·
Soo dealership called they basically have no idea what it means. Says its a generic communication error and they couldn't replicate it. Said they called up the chain to VWoA who said that error is perfectly normal.
Going to start taking pictures when it pops up and i'm sure my car will be back in the shop shortly.
#9 · (Edited)
Nothing really to add, but here's what a fully busted ACC will report :)
*bottomed out bad, lip crushed grill and cracked sensor connector.
Built a harness with 24 awg wires, solder, electrical tape and hot glue to resecure / solder the connector to the unit.
Purged the scan to remove non fault modules, but note, Lane assist threw no codes but was disabled when the module was not functioning.
Address 01: Engine (J623-CYFB) Labels: 06K-907-425-V1.clb
Part No SW: 8V0 906 259 H HW: 06K 907 425 E
Component: 2.0l R4 TFSI H13 0002
Revision: --H13---
Coding: 091D00122466000E3000
Shop #: WSC 01357 011 00200
ASAM Dataset: EV_ECM20TFS0208V0906259H 001003
ROD: EV_ECM20TFS0208V0906259H.rod
VCID: 458A4C0CC48BFD69BC-8010
1 Fault Found:
22008 - No Communications with Cruise Control (Front) Distance Sensor
U0235 00 [039] - -
Not Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Mileage: 11910 km
Date: 2017.01.09
Time: 17:43:22
Engine speed: 696.50 /min
Normed load value: 3.9 %
Vehicle speed: 0 km/h
Coolant temperature: 94 °C
Intake air temperature: 37 °C
Ambient air pressure: 1000 mbar
Voltage terminal 30: 14.785 V
Unlearning counter according OBD: 40
Engine: operating status: IS
ECU_STATE: SYN_ENG_IGK_ON
Engine oil temperature: 80.0 °C
Time since engine start: 78.9 s
T_ES: 0 min
Cruise control switch actuation-Main switch: not activated
Cruise control switch actuation-Setting: not activated
Cruise control switch actuation-Activation: not activated
Cruise control switch actuation-Status: OK
Cruise control switch actuation-Accelerate: not activated
Cruise control switch actuation-Decelerate: not activated
Cruise control switch actuation-Cancel: not activated
Cruise control switch actuation-Main switch hardware: not activated
Cruise control switch actuation-Coding: plausible
Cruise control switch actuation-Limit function: not selected
Cruise control switch actuation-Limit button: not activated
Cruise control switch actuation-Main switch CAN: not activated
Cruise control switch actuation-Large increment: not activated
Cruise control switch actuation-Control component verified: Yes
Readiness: 1010 0101
Address 03: ABS Brakes (J104) Labels: 5Q0-907-379-IPB-V1.clb
Part No SW: 3Q0 907 379 AB HW: 3Q0 907 379 G
Component: ESC H42 0723
Revision: 00000000 Serial number: 60546000001173
Coding: 01FA6BA154260973057B030441CC6980D62A90A0C08296B7184050D8C288
ASAM Dataset: EV_Brake1UDSContiMK100IPB 034036
ROD: EV_Brake1UDSContiMK100IPB_034_VW37.rod
VCID: 7AF0EFF0FDF5429181-802E
4 Faults Found:
8192 - Databus
U1121 00 [009] - Missing Message
Freeze Frame:
Fault Priority: 3
Fault Frequency: 4
Reset counter: 59
Mileage: 11768 km
Date: 2017.01.04
Time: 13:13:49
8195 - Databus
U1122 00 [008] - Implausible Message
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 59
Mileage: 11768 km
Date: 2017.01.04
Time: 13:13:49
8196 - Databus
Freeze Frame:
Fault Priority: 3
Fault Frequency: 7
Reset counter: 59
Mileage: 11768 km
Date: 2017.01.04
Time: 13:13:49
8199 - Databus
U1122 00 [009] - Implausible Message
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 57
Mileage: 11768 km
Date: 2017.01.04
Time: 13:13:49
Cannot be reached
Address 17: Instruments (J285) Labels: 5G0-920-XXX-17.clb
Part No SW: 5G1 920 758 A HW: 5G1 920 758 A
Component: KOMBI 302 6420
Coding: 0BAD081A7F88880902886A0B5400000000000000
ASAM Dataset: EV_DashBoardVDDMQBAB 009046
ROD: EV_DashBoardVDDMQBAB_009_VW26.rod
VCID: 2D5A14AC7C3B252954-8078
3 Faults Found:
16777028 - Function Restricted due to Interrupted Communications
U1110 00 [009] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 5
Reset counter: 59
Mileage: 11698 km
Date: 2017.01.02
Time: 01:55:05
16776960 - Databus
Freeze Frame:
Fault Priority: 2
Fault Frequency: 31
Reset counter: 71
Mileage: 11698 km
Date: 2017.01.02
Time: 01:55:02
16776961 - Databus
Freeze Frame:
Fault Priority: 2
Fault Frequency: 31
Reset counter: 71
Mileage: 11698 km
Date: 2017.01.02
Time: 01:55:02
Address 19: CAN Gateway (J533) Labels: 5Q0-907-530-V1.clb
Part No SW: 5Q0 907 530 AJ HW: 5Q0 907 530 M
Component: GW MQB High 212 2246
Revision: -------- Serial number: 22021610800569
Coding: 0101000838085900FB00023A9C0F00000001050000000000000000000000
ASAM Dataset: EV_GatewConti 013020
ROD: EV_GatewConti_013.rod
VCID: 79F2F0FCF8F3498988-802C
Alternator:
Multi Function Steering Wheel Control Module:
Subsystem 2 - Part No SW: 5G0 959 442 S HW: 5G0 959 442 S Labels: 3C8-959-537.CLB
Component: E221__MFL-DC1 H11 0040
Serial number: 29160000190580016046
Coding: 35FFFF
1 Fault Found:
131671 - No Communications with Cruise Control (Front) Distance Sensor
U0235 00 [009] - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 71
Mileage: 11910 km
Date: 2017.01.09
Time: 17:40:17
Supply voltage: Terminal 30: 14.9 V
Terminal 15: On
Address A5: Frt Sens. Drv. Assist (R242) Labels: 5Q0-980-653.clb
Part No SW: 5Q0 980 653 G HW: 5Q0 980 653
Component: MQB_MFK H07 0060
Serial number: 10000509018
Coding: 0100000000020308000400010100000100
ASAM Dataset: EV_MFKBoschAU370 001001
ROD: EV_MFKBoschAU370.rod
VCID: 3C7C29E8B741BCA1D3-8068
1 Fault Found:
393216 - Databus
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 71
Mileage: 11910 km
Date: 2017.01.09
Time: 17:37:53
Control Module temperature: 24 °C
Outside air temperature: 6.0 °C
Vehicle speed: 0.00 km/h
Voltage terminal 15: 14.8 V
System run time: 150.7 s
#14 ·
That is weird, they told me the lane assist error (had no ACC function) was due to the module/camera on the windshield, and I dont know why they had to take the trim off (scratches on it, from using a pic tool, what tools) all behind the mirror to get it aligned or whatever they had to do with it.
#21 ·
I have just purchased a 2020 jetta sel. I have the same problem the acc regular cruise will work and then later in the day neither will function and I get the yellow cruise id on dash. Went to dealer they looked at it and it showed codes for the day it was snowing which is understandable since the sensor is behind the vw emblem on the grill. I explained to them that this happens on clear days. Of course it functioned perfectly when the tech drove the car and they told me that if it continues they will have to take it up with vw for a resolution.
