Hey all,
I recently ordered a Clutch Switch Bypass harness from AKS Tuning and got absolutely murdered on international shipping charges
. However, I don't really care, because after a few thousand miles of being APR Stage 2+ with Southbend Stage 2 daily, I figured it can only help with respect to prolonging the life of the thrust bearing.
So then I started wondering - exactly what is the bypass harness doing? Reviewing the Erwin wiring diagram for a 2013 Golf R, and understanding the basic fundamentals of a Hall sensor, I think I have a pretty good idea. Now, I won't be able to confirm this until I receive the product and dig into it a bit more, but I do have one potential concern, perhaps you may be able to answer, if you've installed one of these before.
The clutch position sensor (G476) is a Hall sensor that sends a signal to the ECU when it senses the clutch pedal depressed via a magnet affixed to the clutch master cylinder piston coming into close proximity of the sensor itself. The G476 sensor has 4 wires going to it, a "power supply" wire, a ground, and two ECU signal wires. Voltage is applied across the sensor via the power supply wire and the ground wire. When the magnet affixed to the master cylinder piston comes into proximity of the G476, a voltage drop is created across the Hall sensor, called the "Hall Voltage," and sensed by the two ECU signal wires. This tells the ECU if the clutch is depressed or not. Measuring block 066, Field 2, Byte 3, will display a 1 if the clutch is depressed, or a 0 if it is not.
The induced Hall Voltage, a function of the power supply voltage and the strength of the magnet, is typically much less than the actual voltage being supplied to the sensor. How much less in this case, I'm not sure, as I haven't been able to truly test it. But that being said this is the fundamental principle of a Hall sensor.
Now, from what I've heard and read about on the forums/youtube/etc. the bypass harness works by simply jumpering one of the ECU signal wires to the power supply wire such that the ECU always senses a voltage drop on those signal wires such that it believes the clutch is always depressed. Makes enough sense.
However, my concern is regarding the voltage applied to the ECU via the signal wires. Normally, voltage on these signal wires with the clutch depressed is the induced "Hall Voltage," which, like we said earlier, is typically much less than the actual applied voltage to the sensor. In the bypass configuration, the voltage applied to the ECU on the signal wires is now a constant +12 to +14 VDC, assuming the one signal wire was jumpered directly to the power supply wire without an in-series resistor, etc. So, is this okay? Or could this damage the ECU?
In other words, normally, the ECU would sense a hall voltage, periodically, (i.e. each time the clutch is depressed), at a voltage level of something "small" (i.e. less than +12 VDC).
In the bypassed configuration, the ECU would sense a constant +12 to +14 VDC at all times, hence correctly tricking the ECU to believe the clutch is always depressed.
If the ECU terminals where the G476 signal wires connect are rated for only, say, +6 VDC, for whatever reason, not sure if this is right or not, but I do know that ECU signal voltages aren't necessarily battery voltages, hence some ECU terminals/circuits are designed to operate at a voltage less than +12 VDC, then could applying a constant +12 VDC to this specific ECU terminal now cause damage, in the long run?
If so, then I would hope the bypass harness contained a resistor in-line with the jumper to ensure the ECU would not exceed specified voltages for this specific circuit.
Has anyone ever taken apart (i.e. untaped) one of these bypass harnesses to see how exactly it is wired?
Also, if my theory is correct, I could see how such a bypass harness could affect cruise control, assuming the cruise control circuit employs this G476 sensor as well.
I was considering building my own bypass harness - one that adds a parallel pushbutton or other type of switch to the G476 signal wires that can send a simulated signal to the ECU to be used during cranking. Then, the normal clutch position circuit could remain unaffected and provide appropriate signals to the ECU for cruise control and normal driving activity.
Thoughts/comments appreciated.
