Fuel Injector Stuck open, but what else?
1.6K views 5 replies 3 participants last post by  dubluv2003
#1 ·
Been having some issues lately, thought it was a bad coil or plug.. but further inspection says otherwise. Car will run fine at times and others, completely loses power and has a constant misfire. And out of the back of the exhaust is white smoke that reaks of fuel, I even noticed a small stream of fuel leaking out of the exhaust tip this morning. Pulled all the spark plugs out and noticed that in cylinder 3 the (SP) was dripping with fuel when I removed it. All the plugs where black, which means Im running to rich. So I will be changing the plugs out as well as the faulty injector to see if that remedies the problem. However my main question is the white smoke, if I have one injector stuck open wouldnt that cause black smoke rather than white? There is no sweet coolant smell, coolant level hasnt dropped at all, no coolant/oil mixture, so Im ruling out a blown head gasket. Any other ideas?
Car is a 03 1.8 GTI AWP. Stage 2 APR, TBE, SRI, Forge DV, and K-04-001.
Thanks
#4 ·
Also the scan was by an obdII system with a VW program but is not VAg-com. so read outs may be inaccurate. I will scan it again today and report back what Ive got. But i know the injector has failed. Also noticed there is fuel leaking from the turbo exhaust manifold.
#6 ·
Just scanned it:
16684/P0300/000768 - Random/Multiple Cylinder Misfire Detected
16687/P0303/000771 - Cylinder 3 Misfire Detected
16804/P0420/001056 - Catalyst System; Bank 1: Efficiency Below Threshold
and
17635 - Fuel injector short to ground ( which wasnt listed under Ross-Tech Fault Codes page)
Did a compression test, all cylinders hit at 160-168, so head gasket is good.
I am thinking that it is just the injector. Just dont understand the white smoke.
