Got a 16384 error code, any ideas???
28K views 5 replies 3 participants last post by  bluefox280
#1 ·
I could found all my codes, 17544, 16684, 16685, 16687 with the search.
But i can't find the 16384 unknow error code P0303-35-10 intermittent
Any ideas?
thx
#2 ·
Re: Got a 16384 error code, any ideas??? (Mister W)
Well... P0303 is...
* VW DTC 16687 (P0303) - Cylinder 3 Misfire Detected
Are you sure you correctly copied down the VAG-COM fault number?
Because 16384 isn't a powertrain fault code; that's part of a software coding on different platforms to change comfort systems.
- Erik
#3 ·
1 Fault Found:
17544 - Fuel Trim: Bank 1 (Add): System too Lean
P1136 - 35-00 - -
Wednesday, 25 June 2008, 15:08:55
VAG-COM Version: Release 409.1-US
Control Module Part Number: 06A 906 032 LP
Component and/or Version: 1.8L R4/5VT G 0005
Software Coding: 07500
Work Shop Code: WSC 65728
Additional Info: 3VWSE69M72M032492 VWZ7Z0A3839531
4 Faults Found:
16684 - Random/Multiple Cylinder Misfire Detected
P0300 - 35-00 - -
16685 - Shareware Version. To Decode all DTCs
P0301 - 35-00 - Please Register/Activate
16687 - Shareware Version. To Decode all DTCs
P0303 - 35-00 - Please Register/Activate
16384 - Unknown Error Code
P0303 - 35-10 - - - Intermittent
#4 ·
Re: Got a 16384 error code, any ideas??? (bluefox280)
Yeah, so Erik is right, you have a misfiring on cylinder 3. If you had a paid version of vag-com, it would tell you. Anytime you see a "P" followed by 4 or so numbers, that's your code, none of the other 35-00 unknown BS. That's because you're using a shareware version. So, now that that is out of the way, change your coil and plug on cylinder #3
Modified by 87vr6 at 8:25 AM 6-26-2008
#6 ·
Re: (Mister W)
Quote, originally posted by Mister W »
Misfiring are they cause only by coil and sparkplugs?
Coils, spark plugs and ignition coil wiring.
Cause some of my brown wires that goes to the coils are cracked at some places, will that affect and code to misfiring or it will be another code?
Yes!
- Erik
