HELP!!! Messed with the "green menu"... don't know how to get back
19K views 28 replies 3 participants last post by  DrGER
#1 ·
Yup I screwed up. I promise I will never mess with the green menu again!!!
I have some options in the MMI (TPMS reset, wiper service position, etc) that are no longer accesible since messing with the green menu. Forgot what i did and didnt write down what I did. Is there a way to reset ECM's back to factory? Or is this a VagCom thing? If Vagcom, is there a list of factory settings available somewhere? Need some help please!
#2 ·
This topic comes up occasionally on the various forums; I haven't seen anyone yet offer guidance to a relatively simple "factory reset", probably since one doesn't exist for this platform.
Personally, I have a collection of SD1 screenshots (using [TEL]+[MEDIA]) of various GEM configuration screens that I might adjust, just in case. Unfortunately, it seems all to easy to turn off various functions due to (1) lack of adequate end-user (or even developer) documentation and (2) cryptic naming conventions for many configuration parameters.
You might consider running the firmware update on your system in user-defined mode so everything in flash memory is essentially overwritten from the SD media. This might get you back to a more-or-less standard configuration. --g
#6 ·
@drrochet : See my post linked in #4, above. You have a 3G+ system, so you can install firmware HN+_US_AU3G_K0942_6. I also have a PDF that describes firmware & nav database updates here: mmi3gp-updating-20211127.pdf
Thinking some more about this, I'm not so sure the firmware update will affect this, as the Green Engineering Menu (GEM) settings appear to reside in so-called persistent flash memory that doesn't get touched by the update. Still, updating your firmware to K0942_6 is a useful exercise. I'm thinking it might be worth posting a reference collection of working/valid GEM PNG screen shots (using [TEL]+[MEDIA]). I have a few of these from our 2014 A4q that I can post in a new thread here later today that might offer some guidance.
BTW, your navigation data looks to be from the factory: see my post HERE about updating this to NAR 2020. --g
#8 ·
Man you are a God send. Thank you for all your help. I will be doing the updates this week and will take those screen shots for you. I have saved the green menus you have posted. I saw in your signature that you have a 2014 A4. Are you saying that both your A4 and my Q5 share the same green menu selections? Or are there platform specific selections that I should stay away from?
#9 ·
@drrochet : GEM settings are, in general, based on the platform & installed equipment. So, for example, in /car/carcodingvehicle, I wouldn't expect the same settings for an A4 & a Q5. In most of the others, however, I would expect settings to be similar based on installed equipment/options. Use these as a guide -- and keep a blank FAT32 SD card in SD slot 1 so you can grab screens using [TEL]+[MEDIA] before making any changes (the PNG files will have the date/time stamp in the file name). HTH --g
#10 ·
Awesome. I will take all screenshots before I do anything of the entire GEM. Would it be ok if I post em here / PM you the images to see if you can diagnose where I went wrong... or is that too big an ask? Be honest!
#11 ·
@drrochet : Post your GEM images with unusual settings here for the record. I haven't seen much discussion about the topic of GEM settings, in general. This gets something out there for the interweb search engines. --g
#17 ·
Do you have (or have access to) a Ross-Tech VCDS cable ?
One, I'd be concerned about all those DTCs registered in /dtc.
Two, look at this post at AudiWorld: MMI Green Menu Settings for 2014 Q7 TDI - AudiWorld Forums
He seems to have corrected his issues by updating the coding on some modules (though he doesn't say which modules need to be recoded).
My quick look at your GEM /car entries doesn't suggest anything unusual (that would cause these functions to be disabled in the MMI). --g
#18 ·
I just got the RossTech Cable in the mail. Will be looking to get into the VCDS this week. Side note, after doing the Firmware update, I no longer had access to the green menu. Is there a button sequence to reactivate it or do I have to go through VCDS to do so?
#19 ·
The GEM is usually activated by an adaptation to address 5F (MMI main unit J784), which updates some database settings in persistent flash memory on the unit. The database settings can be updated with an SD script, too: Nice script for accessing green screen on 2015 MMI 3G+ - AudiWorld Forums
BTW, have you tried to run a "factory" reset from the MMI Setup menu (MENU > MMI Settings > Factory default settings) ? I came across a thread that suggested this restored menus after an erroneous GEM settting or two (but didn't bookmark it).
A speaking of VCDS, you might find this thread interesting/useful: Complete VCDS - Vagcom mod list
#20 ·
So I hooked up the VCDS to it and tried running some of the check sand diagnostics… As expected nothing changed nor was I able to find the issues at hand. I will check in with Ross Tech to see if they have any inclination regarding the specific issues I am having. Followed the links to the posts you sent me and even just activating the clock functions didn’t work (using the GEM)…. Would love someone with a clean Q5 to post their GEM settings as a benchmark!!!!
#23 ·
  • Like
Reactions: drrochet
#24 ·
@drrochet : Did you get this figured out ? Someone on AudiWorld just figured out this has to do with the /car/carprotcollswitch menu: Green Menu help - AudiWorld Forums
But should also be visible in the Long Coding helper of Address 5F in VCDS (see long coding byte references to menu settings here: MMI 3G+ J794 Coding and Adaptations ) --g
Hey bud, been a while. Big thanks for those links. I am just now getting back around to seeing if I can restore the values on the Q5. I will try that /car/carprotocollswitch option tonight before getting into the longcoding process. I have been reading up on using the VCDS with the long coding feature to attempt to properly set the values for the features that have been affected. This video (
) is one that has at least given me some direction with that. You are awesome. Thanks for following up. I'd buy you a drink if I could!🥃
#26 · (Edited)
@DrGER
Monday,30,May,2022,19:23:30:24559
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x86
VCDS Version: 22.3.1.4 HEX-V2 CB: 0.4615.4
Data version: 20220407 DS337.0
www.Ross-Tech.com
Chassis Type: FP-AU48 (8R0)
Scan: 01 02 03 05 08 09 15 16 17 19 36 3C 42 44 46 47 52 53 56 5F
62 6C 6D 72
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
05-Acc/Start Auth. -- Status: Malfunction 0010
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
36-Seat Mem. Drvr -- Status: OK 0000
3C-Lane Change -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
47-Sound System -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: OK 0000
56-Radio -- Status: OK 0000
5F-Information Electr. -- Status: Malfunction 0010
62-Door, Rear Left -- Status: OK 0000
6C-Back-up Cam. -- Status: OK 0000
6D-Trunk Elect. -- Status: OK 0000
Address 01: Engine (DET-CPMB) Labels:. 06H-907-115-CDN.clb
Part No SW: 8R1 907 115 L HW: 8K2 907 115 L
Component: 2.0l R4/4V TF H09 0005
Revision: ECH09--- CVN: E5EDE92F
Coding: 6A2A0013242600062000
Shop #: WSC 44796 003 1048576
ASAM Dataset: EV_ECM20TFS0118R1907115L 001006
ROD: EV_ECM20TFS0118R1907115L.rod
VCID: 3E253171D0F24B0BFD3-806A
VINID: 9D105C5915A01D6441001201148826CB00
1 Fault Found:
4106 - Bank 1; System too Rich at Idle
P2188 00 [096] - -
Intermittent - Not Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 1
Mileage: 176812 km
Date: 2022.05.28
Time: 11:33:14
Engine RPM: 820.50 /min
Normed load value: 25.9 %
Vehicle speed: 0 km/h
Coolant temperature: 96 °C
Intake air temperature: 58 °C
Ambient air pressure: 1010 mbar
Voltage terminal 30: 13.923 V
Unlearning counter according OBD: 40
Engine status: COENG_RUNNING
Engine status-Test_Program_Co Eng st COMPU VERB UBYTE: 3
Readiness: 0000 0000
Address 02: Auto Trans (J217) Labels:| 0BK-927-156.clb
Part No SW: 8R0 927 158 AS HW: 0BK 927 156 AL
Component: 0BK 20TFSIUSA H19 1002
Revision: --H19--- CVN: 982CFC97
Coding: 000001
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_TCMAL551211 002022
ROD: EV_TCMAL551211_002_AU48.rod
VCID: 0E45A1B1A0D29B8B4D3-805A
No fault code found.
Address 03: ABS Brakes (J104) Labels:. 8R0-907-379-V2.clb
Part No SW: 8R0 907 379 AS HW: 8R0 907 379 AS
Component: ESP8 quattro H09 0020
Revision: -------- Serial number: --------------
Coding: 151D1803
Shop #: WSC 06335 000 00000
VCID: 117FBACDB16C8473501-8044
Address 05: Acc/Start Auth. (J393) Labels:. 8K0-907-064-05.clb
Part No SW: 8K0 907 064 KP HW: 8K0 907 064 KP
Component: BCM2 2.0 H15 0711
Revision: 00002001
Coding: 0D854040000000000000
VCID: 084997A9C236C5BB87F-805C
Subsystem 1 - Part No SW: 8K0 959 754 B HW: 8K0 959 754 B
Component: FBSAUDIB8 IDG H71 0083
Serial number: 0515000012798016
Subsystem 2 - Part No SW: 8K0 905 852 E HW: 8K0 905 852 E
Component: J764 ELV MLB H40 0046
Serial number: 3215000018254003
2 Faults Found:
00955 - Key 1
002 - Lower Limit Exceeded
Freeze Frame:
Fault Status: 01100010
Fault Priority: 3
Fault Frequency: 1
Reset counter: 213
Mileage: 176472 km
Time Indication: 0
Date: 2022.05.20
Time: 05:59:01
00956 - Key 2
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 214
Mileage: 176490 km
Time Indication: 0
Date: 2022.05.20
Time: 12:48:15
Address 08: Auto HVAC (J255) Labels:. 8Kx-820-043-3Z.clb
Part No SW: 8K1 820 043 AQ HW: 8K1 820 043 AQ
Component: KLIMA 3 ZONEN H04 0123
Revision: C1000000 Serial number: 01030220151855
Coding: 6481208000
VCID: 77ABE455BFC8BA43FE5-8022
Address 09: Cent. Elect. (J519) Labels: 8K0-907-063.clb
Part No SW: 8K0 907 063 DH HW: 8K0 907 063 DH
Component: BCM1 1.0 H16 BCM1 1.0 H16 01030103
Revision: 08016001 Serial number: 00000997359201
Coding: 26000091813CAFC00000480300003D0D0F1C4608A2090221000008004000030100000034000000
Shop #: WSC 06335 123 12345
VCID: 78A9E769B2D6B53BF7F-802C
Subsystem 1 - Part No SW: 8R1 955 119 A HW: 8R1 955 119 Labels: 1KX-955-119.CLB
Component: WWS416 150116 H12 0050
Serial number: 90243014141218003057
Coding: 01DD13
Subsystem 2 - Part No SW: 8U0 955 559 C HW: 8U0 955 559 B Labels: 8U0-955-559.CLB
Component: G397_RLFS H06 0004
Serial number: 20113524
Coding: 02005C
Subsystem 3 - Part No SW: 8K0 941 531 AS HW: 8K0 941 531 AS
Component: E1 - LDS H03 0031
Serial number: 00000000002901150201
Subsystem 4 - Part No: 4G0 907 410 A
Component: USHL4.2
Subsystem 5 - Part No: 4H0 907 658
Component: AQ_Hum_Sensor
No Faults Found
or DTCs not supported by controller
or a communication error occurred
Address 15: Airbags (J234) Labels:| 8K0-959-655.clb
Part No SW: 8K0 959 655 R HW: 8K0 959 655 R
Component: AirbagVW-AU10 H51 0812
Serial number: 003NED1359XI
Coding: 303635313832383132304A55304C38523053
ASAM Dataset: EV_AirbaECUVWAUDI010 003114
ROD: EV_AirbaECUVWAUDI010_003_AU48.rod
VCID: 4CC16BB9964EE99B637-8018
Seat occupied recognition:
Subsystem 1 - Part No SW: 8R0 959 339 A HW: 8R0 959 339 A
Component: BF-Gewichtss. H02 0040
Serial number: 5810000R150000JTAQ
Crash sensor for side airbag: driver side:
Serial number: 6334MSME4D5B2E76Z
Front Passenger's Side Airbag Crash Sensor:
Serial number: 6344MSME4E2E0E04Q
Rear Side Airbag Crash Sensor (on driver's side):
Serial number: 6352QSME314B1668H
Passenger side rear thorax airbag crash sensor:
Serial number: 6362QSME03501064/
Crash sensor for front airbag: driver side:
Serial number: 63732SME274D4264+
Crash sensor for front airbag: front passenger side:
Serial number: 63832SME1950377C1
Address 16: Steering wheel (J527) Labels:. 8K0-953-568.clb
Part No SW: 8K0 953 568 Q HW: 8K0 953 568 Q
Component: Lenks.Modul H03 0003
Revision: C0062331 Serial number: 90862OB2001NB
Coding: 000017
VCID: 48C957A982B605BB47F-801C
Component: E221 - MFL H03 0004
Address 17: Instruments (J285) Labels:. 8R0-920-xxx-17.clb
Part No SW: 8R0 920 981 N HW: 8R0 920 981 N
Component: KOMBIINSTR. H35 0567
Revision: 00100000 Serial number: 03649AX1G
Coding: 8BB522000301D705020200
VCID: 45D75E9DB5A418D3BC9-8010
Address 19: CAN Gateway (J533) Labels:. 8T0-907-468.clb
Part No SW: 8R0 907 468 P HW: 8R0 907 468 D
Component: GW-BEM 5CAN-M H11 0060
Revision: 1Z120030 Serial number: 3041Z151240686
Coding: 80C303FF00
VCID: 4CC16BB996CEE99B637-8018
Subsystem 1 - Part No SW: 8R0 915 181 C HW: 8R0 915 181 C
Component: J367-BDMHella H07 8043
Serial number: 0139355403
1 Fault Found:
03041 - Energy Management Active
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 7
Fault Frequency: 2
Reset counter: 253
Mileage: 176472 km
Time Indication: 0
Date: 2022.05.19
Time: 20:51:58
Freeze Frame:
Bin. Bits: 10111
Voltage: 11.60 V
Count: 6
Address 36: Seat Mem. Drvr (J136) Labels: None
Part No SW: 8R0 959 760 D HW: 8R0 959 760 B
Component: MEM-FS H07 0077
Revision: AA000000 Serial number: 00000133830639
Coding: 00581B00000000000000
VCID: 42DD4581A48A2FEB99B-8016
Address 3C: Lane Change (J769) Labels:| 5Q0-907-566.clb
Part No SW: 8T0 907 566 B HW: 8T0 907 566 B
Component: SWA Master H05 0071
Serial number: 0358463317
Coding: 010211
Shop #: WSC 06334 000 00000
ASAM Dataset: EV_LaneChangAssis 001020
ROD: EV_LaneChangAssis_AU21.rod
VCID: 3FDB4C75D7F84203F65-806A
Lane change assistance control module 2:
Subsystem 1 - Part No SW: 8T0 907 568 B HW: 8T0 907 568 B
Component: SWA Slave H05 0071
Serial number: 0358497527
Coding: 010211
1 Fault Found:
730117 - Control Module 2 for Lane-Change Assist
C1115 F0 [009] - Automatic Calibration Not Possible
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 213
Mileage: 176472 km
Date: 2022.05.19
Time: 20:52:00
Address 42: Door Elect, Driver (J386) Labels:. 8K0-959-793.clb
Part No SW: 8K0 959 793 R HW: 8K0 959 793 P
Component: TSG FA H02 0510
Revision: Serial number: 0000133597021
Coding: 011D13205E00440004
VCID: 4FFB7CB567D8D283065-801A
Address 44: Steering Assist (J500) Labels:| 8K0-909-144.clb
Part No SW: 8R0 909 144 J HW: 8R0 909 144 B
Component: RCEPS H41 0509
Revision: 00001000 Serial number: 0007392841
Coding: 100000000000
ASAM Dataset: EV_RCEPSAU48X 008016
ROD: EV_RCEPSAU48X_008.rod
Address 46: Central Conv. (J393) Labels:. 8K0-907-064-46.clb
Revision: 00002001 Serial number: 0359228164
Coding: 01260E3A20FA709587B0053200040000
Shop #: WSC 06334 123 12345
Subsystem 1 - Part No SW: 8K0 959 719 B HW: 8K0 959 719
Component: GTO BF H01 0080
Serial number: 00000000009999999999
Subsystem 2 - Part No: 1K0 951 605 C
Component: LIN BACKUP HO H05 1501
Subsystem 3 - Part No SW: 7N0 959 591 B HW: 7N0 959 591 B
Component: J245EE04SKB03 H03 0090
Serial number: 0123456789ABCDEFGHIJ
Subsystem 4 - Part No SW: 7N0 959 591 B HW: 7N0 959 591 B
Component: J394EE04SKB03 H03 0090
Address 47: Sound System (J525) Labels:. 8T0-035-223-BOM.clb
Part No SW: 8T1 035 223 A HW: 8T1 035 223 A
Component: DSP Prem H05 0030
Revision: 00005001 Serial number: 94813039823506
VCID: 2D07063D0D14C093549-8078
3 Faults Found:
02558 - Rear Left Mid-Range/Woofer Loudspeaker (R159)
011 - Open Circuit - Intermittent
Freeze Frame:
Fault Status: 00101011
Fault Priority: 5
Fault Frequency: 34
Reset counter: 12
Time Indication: 0
Freeze Frame:
Voltage: 12.50 V
Temperature: 57.0°C
Temperature: 60.0°C
Bin. Bits: 00000100
02559 - Rear Right Mid-Range/Woofer Loudspeaker (R160)
Freeze Frame:
Fault Priority: 5
Fault Frequency: 34
Reset counter: 12
Time Indication: 0
Freeze Frame:
Voltage: 12.50 V
Temperature: 57.0°C
Temperature: 60.0°C
Bin. Bits: 00000100
03029 - Subwoofer (R157)
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 253
Time Indication: 0
Freeze Frame:
Voltage: 12.50 V
Temperature: 57.0°C
Temperature: 60.0°C
Bin. Bits: 00000100
Address 52: Door Elect, Pass. (J387) Labels:. 8K0-959-792.clb
Part No SW: 8K0 959 792 R HW: 8K0 959 792 P
Component: TSG BF H02 0510
Revision: Serial number: 0000134301082
VCID: 4EC561B160D2DB8B0D3-801A
Address 53: Parking Brake (----) Labels: 8K0-907-801-V2.clb
Part No SW: 8K0 907 801 N HW: 8K0 907 801 J
Component: EPB-4 H02 0005
Revision: -------- Serial number: 30000000329187
ASAM Dataset: EV_ParkiBrake 001028
ROD: EV_ParkiBrake_AU48.rod
VCID: 3A2D3D61CCDA672BC1B-806E
Address 56: Radio (R) Labels:. 4F0-035-0xx-56.clb
Part No SW: 4G0 035 082 H HW: 4G0 035 082
Component: Radio U SIRIU H66 0138
Revision: AB001007 Serial number: 156BX0F8190163
Coding: 020007010000000001
VCID: 2517FE1D55E4F8D39C9-8070
Address 5F: Information Electr. (J794) Labels:. 4E0-035-6xx-5F.clb
Part No SW: 8R1 035 746 K HW: 8R1 035 746 G
Component: H-BNT-NA H42 1040
Revision: -------- Serial number: 523BU0F7523460
Coding: 160200060005E1FF43029F5E00000403140000000000000102
VCID: 3FDB4C75D7784203F65-806A
Subsystem 1 - Part No: 8R0 060 884 CJ
Component: NAR 2015 1102
Subsystem 2 - Part No SW: 8R0 919 604 A HW: 8R0 919 604 A
Component: DU7 High H42 0104
Serial number: A130AI0F3247213
Subsystem 3 - Part No SW: 8T0 919 611 L HW: 8T0 919 611 C
Component: E0380 Bedient H02 0030
Serial number: 00000002117988
Subsystem 4 - Part No: 8R0 060 961 G
Component: CD-Database 5950
2 Faults Found:
03276 - Please Check Software Version Management
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 6
Fault Frequency: 1
Reset counter: 227
Mileage: 176821 km
Time Indication: 0
Date: 2022.05.30
Time: 07:59:08
Freeze Frame:
Text: DUA130,,D,0,0,6
03157 - Functionality limited due to Communications Disruption
Freeze Frame:
Fault Priority: 6
Fault Frequency: 6
Reset counter: 8
Mileage: 176736 km
Time Indication: 0
Date: 2022.05.24
Time: 13:26:28
Freeze Frame:
Bin. Bits: 00000001 00000000
Bin. Bits: 00000000 00000000
Address 62: Door, Rear Left (J388) Labels:. 8K0-959-795.clb
Part No SW: 8K0 959 795 G HW: 8K0 959 795 D
Component: TSG HL H01 0510
Revision: Serial number: 0000133638698
Coding: 010C13204000240004
VCID: 46D5599188A213CBB53-8012
Address 6C: Back-up Cam. Labels: 8T0-907-441.clb
Part No SW: 8R0 907 441 A HW: 4L0 907 441 B
Component: J772__Rearview 0040
Revision: --H09--- Serial number: 525PA8-J4YA3PU
Coding: 1020010
VCID: 34311359E23E915B1B7-8060
Address 6D: Trunk Elect. (J605) Labels: 8K9-827-851.clb
Part No SW: 8R0 827 851 D HW: 8R0 827 851 D
Component: J605 Master H56 0330
Revision: -------- Serial number: 8R0827851D
VCID: 3D27367DDD745013E49-8068
Subsystem 1 - Part No SW: 8R0 827 852 D HW: 8R0 827 852 D
Component: J756 Slave H56 0330
Serial number: 8R0827852D
Address 72: Door, Rear Right (J389) Labels:. 8K0-959-795.clb
Component: TSG HR H01 0510
Revision: Serial number: 0000133636519
End----(Elapsed Time: 02:56, VBatt start/end: 11.8V/11.7V. VIgn 11.7V)-----
#27 ·
@drrochet : In Address 5F, your Byte 08 is set to 0x43, which sets bits 0 (Menu Central Locking), 1 (Menu Compass), and 6 (Menu Seat Memory Front). You have Address 3C: Lane Change (J769), so I would expect bit 4 (Menu Lane Change assist) to be set, also. DTC 03157 is likely related to this misconfiguration (or other recent configuration updates made on or about 24 May). See: Audi Map 2017 6.24.2 8R0051884ED 8R0060884ED
Our A4Q has Byte 08 set to 0x45: bits 0 (Central Locking), 2 (Drive Select), and 6 (Seat Memory Front). Make sure when you set a menu bit in the long coding that you have the related hardware installed.
DTC 03276 is related usually to user-initiated software updates in the Red Engineering Menu. Did you updated the MMI software recently to K0942_6 ? DTC 03276 is cleared with Adaptation Channel 15. The DTC at Address 19 was due to low starter battery voltage (11.6V). --g
  • Like
Reactions: drrochet
#28 ·
@DrGER cheers!!! I will look into the issues in 5F with your recommendations. I did your MMI firmware upgrade so I will also go through the Adaptation settings and give it a once through. Thanks for the directions!
A little off topic but... since I have your attention I will ask. I have a 2018 S5 that seems to be getting transmission stuck in S mode, even when not in S mode. Idles at 900 in Auto, Comfort, even Dynamic Normal. Transmission wont manually or automatically shift out of 7th gear below 60 mph. It is an intermittent issue, but noticing it more now that is is getting real hot here in South Florida. I've done some reading into and some people are doing some type of TCU reset and having mixed results. Any experience with this? Any remedy through VCDS? Worth taking it to Audi for eval? I have an extended on it so repairs are manageable... figure any less time I can leave it with them, the better. Thanks bud.
#29 ·
Good luck with getting your MMI back on-line fully -- sounds like you're making headway there.
As for transmissions, we only drive MTs in our house (last AT was in 1991?). The B8/Q5 forums over at Audizine are fairly knowledgeable. You might post your TCU question over there -- I would suppose the TCU has an adaptation for that kind of thing, but if it's intermittent, that might suggest mechatronics? But no DTCs from your TCU, above, at least. The extended warranty definitely helps. --g
  • Like
Reactions: drrochet
