I have a 2008 4 door rabbit. After I had the battery replaced in the car the instrument cluster is now showing a small "1" on the upper right corner and the center is showing a timer in minutes that counts up. This is after the key is turned onto the accessory section. It says "0 min", "1 min", etc. Does not reset after you take the key out and put it back in. Any idea what this is and how to go back to the standard display? This has replaced the range in miles display. bizarre.
I tried going through motions of resetting the service indicator but it does not make a difference.
