Re: isv reroute questions (ag602nv)
a stock G60 engine is loosing about 0.2 Bar of pressure (don't know psi)
through the Idle Stabilizer Valve. the reroute solves this problem. I myself got a boosvalve between the intake manifold and the ISV so no pressure is lost. Do mind that you need a Chip reprogram to run safe. because at high rpms the charger is blowing so much air, and now none is lost, that the CO is dropping dangerously low since the chip is not programmed for also injecting more fuel.
furthermore there is especially a huge thorque gain in the lower rpms
