VAG-COM coding from Golf MK5 with cruise control - MFD - buttons on wheel
11K views 4 replies 3 participants last post by  Theresias
#1 ·
Hi guys
because here in greece the cruise control isn't on standar equipment i buy a new control (1k0 953 513 A) with cruise control.
I installed it but i doesn't make it to turn on ( i change the code with VAG - COM
First i change from Address 01-Engine->07 Coding 6th byte from 00 to 01)
then in Address 16 - Steering wheel -> 07 Coding
i had 000 20 02 from factory (steering wheel with buttons and multifuction display)
Can anyone have steering wheel with buttons, multifuction display and cruise control from factory to give me the coding from this address
thank u
Modified by aLdon at 1:27 AM 11-1-2007
#2 ·
Re: VAG-COM coding from Golf MK5 with cruise control - MFD - buttons on wheel (aLdon)
The steering wheel elctrocnics used in a car without cruise control has a different part # that the one in a car with cruise control. You may have to replaced the steering wheel electronics in order to be able to change codings. No all control unit accept all codings. I will try to find you a code and send it to you so you can try.
#3 ·
The cruise control buttons on the wheel usually do not prevent one from coding, at least not in this particular case. The coding table for the steering column control can be found in VAG-COM and also in our WIKI.
http://wiki.ross-tech.com/inde...Wheel
A very common problem is that the installed steering column control module is simply not compatible, so the 1st thing you should do for now is to post a complete Auto-Scan from the car so we can see which options you do have installed and which you don't.
#4 ·
Re: VAG-COM coding from Golf MK5 with cruise control - MFD - buttons on wheel (Theresias)
Tuesday,30,October,2007,04:57:18:55371
VAG-COM Version: Release 704.1
Data version: 20070422
Chassis Type: 1K0
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56
VIN: WVWZZZ1KZ7W267917 Mileage: 5960km/3703miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: OK 0000
Address 01: Engine Labels: 06F-907-115-AXX.LBL
Part No SW: 1K0 907 115 L HW: 8P0 907 115 B
Component: 2.0l R4/4V TFSI 0030
Coding: 0403000318070160 (i change it from 00 to 01)
Shop #: WSC 01287
No fault code found.
Readiness: 0110 0101
Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.LBL
Part No SW: 1K0 907 379 AC HW: 1K0 907 379 AC
Component: ESP FRONT MK60 0101
Coding: 0004738
Shop #: WSC 01287
Address 08: Auto HVAC Labels: 1K0-907-044.LBL
Part No SW: 1K0 907 044 BN HW: 1K0 907 044 BN
Component: ClimatronicPQ35 110 1010
Address 09: Cent. Elect. Labels: 3C0-937-049.LBL
Part No SW: 3C0 937 049 AE HW: 3C0 937 049 AE
Component: Bordnetz-SG H52 2002
Coding: E58D8F3700041800001600001400000000097F075C0000
Shop #: WSC 03040
Part No: 1K1 955 119 E
Component: Wischer 200407 021 0501
Coding: 00038805
Shop #: WSC 03040
Part No: 1K0 955 559 AB
Component: RLS 240407 020 0105
Coding: 00208933
Shop #: WSC 03040
Address 15: Airbags Labels: 1K0-909-605.LBL
Part No SW: 1K0 909 605 T HW: 1K0 909 605 T
Component: 37 AIRBAG VW8 020 2300
Coding: 0013111
Shop #: WSC 01269
Address 16: Steering wheel Labels: 1K0-953-549.LBL
Part No SW: 1K0 953 549 BD HW: 1K0 953 549 BD
Component: J0527 638 0070
Coding: 0002002
Shop #: WSC 01287
Part No: XXXXXXXXXXX
Component: E0221 002 0010
Address 17: Instruments Labels: 1K0-920-xxx-17.LBL
Part No SW: 1K6 920 873 HW: 1K6 920 873
Component: KOMBIINSTRUMENT VDD 1610
Coding: 0001103
Shop #: WSC 03011
Address 19: CAN Gateway Labels: 1K0-907-530.LBL
Part No SW: 1K0 907 530 K HW: 1K0 907 951
Component: J533__Gateway H04 0021
Coding: 3D0F034007000000
Shop #: WSC 01287
Address 25: Immobilizer Labels: 1K0-920-xxx-25.LBL
Component: IMMO VDD 1610
Address 42: Door Elect, Driver Labels: None
Part No SW: 1K0 959 701 M HW: 1K0 959 701 M
Component: Tuer-SG 005 0983
Coding: 0000052
Shop #: WSC 01287
Address 44: Steering Assist Labels: 1Kx-909-14x.LBL
Part No: 1K1 909 144 L
Component: EPS_ZFLS Kl.074 H07 1806
Address 46: Central Conv. Labels: 1K0-959-433-46.LBL
Part No SW: 1K0 959 433 BT HW: 1K0 959 433 BT
Component: KSG PQ35 G2 020 0204
Coding: 899002085103087F2D048D0D70084AC6F0BC00
Shop #: WSC 01367
Part No: 1K0 951 605 C
Component: LIN BACKUP HORN H03 1301
Part No: 1K0 951 178 A
Component: Neigungssensor 003 0203
Component: Innenraumueberw.003 0203
Address 52: Door Elect, Pass. Labels: None
Part No SW: 1K0 959 702 M HW: 1K0 959 702 M
Coding: 0000052
Shop #: WSC 01287
Address 56: Radio Labels: 1K0-035-1xx-56.LBL
Part No: 1K0 035 186 T
Component: Radio GR0 020 0023
Coding: 0040400
Shop #: WSC 01287
End --------------------------------------------------------------------------------------------------
The icon display turned on speedometer when i clik on/off from switch. The problem is the cruise doesn't enable.
i try those coding but i didn't make to enabled.
000 0 0 22
000 0 0 42
000 2 0 22
000 2 0 42
000 3 0 22
000 3 0 42
Modified by aLdon at 12:39 AM 11-1-2007
