Vag-com not working properly.
9.5K views 9 replies 6 participants last post by  frandre
#1 ·
OK so I have the Hex-can-usb cord I bought new from ross-tech. I have not used it in a while and just scanned my 2002 A6, 3.0 tip, Q.
I checked for any upgrades to the programming, and did a firmware update. Went to scan and All i get is a interface check screen.
It says as follows...
X interface status=0
Interface not ready!
possible reasons:
incorrect com port selected------I tested this and saved it
Interface not plugged in----- had green light on obd connector and connected to the laptop port.
Ignition not turned on---Key was in the on/run position
K-line stuck----No clue???
firmware update needed----Started off dand completed a firmware update at the start.
For more details, use TEST on options screen...
Now just before this screen popped up. Vag-com completed a scan on the engine and then the trans. Then the above screen pops up, and cant go any farther.
it is VCDS release 11.11.4 , and running on windows vista.
Unfortunatly I am not a computer geek, so need good direction as to how to correct this issue.
Any and all help is greatly appreciated.
#6 ·
Have you has any luck? My Ross tech vcds has been acting up ever since I updated to 11.11.4 software. I've tries everything I can think of but it just keeps saying Usb interface not found when I try to test and save under options.
Sent from my GNex using Tapatalk 2
#7 ·
I can say that after last few updates, VCDS is more complicate to operate. For example in long past - sofware was more stable. Now more time software is frozen, WInXp or Win7, it's hard to close VCDS.exe from Windows process (hard reset) need to reset whole PC, re-plug from USB and (or) from CAR not helping.
In never happen before
My 2nd one with COM interface working little bit better, but close Software from (alst + ctrl+del) when is froze is also very hard even impossible.
#8 ·
OK so little update.
I decided to try on mine on a audi A3, it scanned the entire system no problems.
This was a 2007 A3, but tried again and same thing wont go past the transmission scan. I even did a module scan, did the engine, scanned no problem at first. Then before I can click on measuring blocks it stops. a message saying something like controler not connetected . unfortunatly my laptop shut down due to low battery, wife pluged it in and went to use it before I could double check the message.
car runs but has a misfire , but when i try to scan, i get error messages and cant go any farther.
James K.
