VW.com exhaust tips.....DEFECTIVE!!
912 views 12 replies 9 participants last post by  sssnice
#1 ·
I recently bought the VW.com exhaust tips used from a fellow Vortexer, so today I went and install them and to my surprise, the right tip hangs HIGHER than the left
I've checked everything I did and even checked if the muffler itself is tilted. Everything seems to be OK. Then I checked the tips and turns out that the little rectangular metal that holds the tips together is not accurately welded to the proper places of the tips. Not only are the tips tilted, but they also don't line up straight. What can I do? What can I do to correct this? I don't have a receipt since I got it used, and I don't wanna fuss with sending it back to the seller. If I go to my dealer for this problem, would they back me up on this? Thanks.
#7 ·
Re: VW.com exhaust tips.....DEFECTIVE!! (Gee Spoolin)
quote:[HR][/HR] What can I do? What can I do to correct this? I don't have a receipt since I got it used, and I don't wanna fuss with sending it back to the seller. If I go to my dealer for this problem, would they back me up on this? Thanks.[HR][/HR]​
You bought it used, and you want the dealer (who you didn't buy it from) to help you out? Please let us know how much help the dealer gives you.
#10 ·
Re: VW.com exhaust tips.....DEFECTIVE!! (VWThug)
Hey, people. I followed MatchStick's advice and bended the tips to be straight, but I did it using a clamp, which worked well. After putting the tips on, I was thinking "problem's solved" and started the car. To my surprise, the tips rattled like hell!!!!
Then I found that it was because the tips are too close to each other and this can't be corrected by bending them apart, since there is a little piece of metal that holds them together. Now I'm pissed
I can't believe putting the tips would cause such a dilema
, can someone help?
#12 ·
*shrug*
Mine never rattled. Sorry dude... I am giving mine away locally if anyone is interested. Gotta be local though - you come to me. They have some scratches from hitting my old driveway underneath, but not noticeable when viewed from anywhere but below. Hence the "free" part.
#13 ·
Re: VW.com exhaust tips.....DEFECTIVE!! (MatchStick)
mine weren't bent but I had to trim some pipe off before welding them on. They aren't totally parallel to the ground now and point up a bit. I haven't had a problem with condensation yet but if I do I guess I'll have to drill a couple of holes at the low point of the pipe.
