Weird behavior and even weirder codes... "was this limp mode"?
34K views 43 replies 23 participants last post by  ms0241
#1 ·
Mods:
APR Tuned, Stage 1
APR Intake
While accelerating out of the apex of a flyover onto the tollway in 5th approaching WOT (and the speed limit), when I shifted to 6th the car shook once, the EPC light came on, and I could no longer shift, accelerate, or maintain speed. No blinking, no yellow engine light that I can recall.
Pulling off on the side of the tollway the car was running like someone tore off several vacuum lines (very rough idle, shaking). Shutdown and restart and the problem was gone.
When I got home I pulled the following codes, which I have never seen before:
15138 - Control Module Malfunction - DBW Throttle Monitoring
P1388 00 [032] - -
Intermittent - Not Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 1
Mileage: 11240 km
Date: 2015.09.12
Time: 14:32:01
15396 - Cam Adjustment Actuator A; Cylinder 2
P11A6 00 [096] - Implausible Signal
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 11241 km
Date: 2015.09.12
Time: 14:32:22
15414 - Cam Adjustment Actuator B; Cylinder 1
P11A4 00 [096] - Implausible Signal
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 11241 km
Date: 2015.09.12
Time: 14:32:23
15418 - Cam Adjustment Actuator B; Cylinder 3
P11AC 00 [096] - Implausible Signal
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 11241 km
Date: 2015.09.12
Time: 14:32:24
Any clues on what the hell happened to my car today?
For what it's worth, I've had another incident occur two or three times when at the top of 1st near redline before shifting to 2nd, where the car cuts all power and snaps me into my seatbelt (could be related).
Any input is appreciated :)
#2 ·
Mods:
APR Tuned, Stage 1
APR Intake
I think there has been mention of accelereating in higher gears, no matter of tune or not, that this situation has happened. I'm sure you will get some good info on this by the end of the day.
#3 ·
Thanks Vegas. When I searched by the problem description the lead that came up most was overboost/boost spike on shift from 5->6, but the codes don't seem to reflect that. Searching by the codes yielded next to nothing.
#5 ·
This same thing happened to me a couple times when I first went stage 1. Now recently I did a catless downpipe and catback. I have been running them for like 2 weeks with no problems (except a CEL for the cat). Now last night my car went in limp mode twice while out driving. Got home and pulled the codes and had basically the same codes as you. Being that my car threw the same codes before the downpipe I don't think they're related, but I am now again very interested in what can cause this.
#7 · (Edited)
This is a known issue to APR
Mk7 R, APR Stage 1, VWR R600 Intake, GFB DV+
Basically the same set of codes (though my initial code was an inconsistent signal from the ECU, then the cam codes) has been happening to me. I've had my R tuned since July 3 without a problem. But about a month ago now, as soon as we had our first cool morning in Northern Virginia, I dumped into limp mode while accelerating hard to pass someone. This issue is something that I have been able to repeat multiple times. It is apparently a known "overboost" issue on the APR Stage 1 tune.
The circumstances when this triggers have all been very nearly identical:
Air temperature around 70 degrees, mildly humid, car at running temperature, going a steady rate of speed between 45-55 mph. I step on the gas, maybe 3/4 throttle to pass or something. I get maybe about 2-3 seconds of good acceleration and boost. Then the car dumps itself into limp mode with a rough idle. I pull over, shut the car off, restart it, and it's normal again.
What NGP Racing in Lorton, VA (who did my tune) said is that APR is receiving matching reports with these symptoms from a number of Mk7 R and S3 owners under hard acceleration at speed. They have been looking into the prtoblem, but had not been able to reproduce the problem themselves while recording data I was told.
Three Mondays back, I went in to NGP, they hooked up APR's logging system, and I was able to dump the car for them while they were logging. NGP sent the log to APR engineering, who is apparently still reviewing to determine a permanent solution.
In the meanwhile, NGP said a temporary solution is that they can reflash my R to the low output Stage 1 tune instead of the high output, and that should eliminate the issue. That said, I told them I would keep the car as is in case they need me to try to reproduce again for them for additional data.
I will try to remember to check back in and follow up once I hear from NGP and APR about a permanent fix/reflash.
#10 ·
Checking back in. Still no solution from APR, but according to NGP, I am far from the only one reporting this issue to them (as mentioned previously). Here's hoping the permanent solution is pending soon.
And a question @cantgetenoughmk7r: You say that you re not having any issues with the Stage 2 tune? Just curious, as I m starting to feel like that may just be my "solution" to this problem.
#11 ·
I also received the same codes yesterday, going into limp mode. I was on a highway going up a large bridge doing around 90mph. I went to make a pass and floored it in 5th gear. About 2 seconds after hitting boost the car goes into limp mode. By the time I got to the top of the bridge, I was doing 30mph, and coasted down to the bottom. Cars travel at a very high rate of speed on this road, and there is no shoulder, so unfortunately I did not feel safe stopping to reset, especially since it was night time.
Shut the car off, and back on, and everything was back to normal. Waiting for a second response from APR. The initial response I received suggested that my spark plugs may have gone bad......
I hope they can sort this out with an update soon.
#12 ·
I hope you guys with APR get this figured out. I've had GIAC stage 1 since the day it was released in the states and fortunately I have not hit limp mode once.
#13 ·
Thanks, I'm sure it will get squared away quickly. I never expect everything to be perfect, and they will always learn things with a new engine (since there were some differences with the US spec R vs EU).
This is my 3rd 2.0T with APR software, and I'll continue to be a customer of theirs for years to come.
#24 ·
I went searching for this as its been happening on my car and to my surprise came across this thread. Getting the P11A6 in my S3, seems to happen under same situation as others (usually highway speed, give it some gas 3/4-full throttle and after 2-3 seconds it throws itself into limp mode, especially in 5th gear). My P3 gauge isn't showing overboost, but it could certainly be happening. Not really sure what the issue is. Note I'm on UM stage 2 with a down pipe. I know when I first went stage 2 it was doing this, but that as due to lag spikes. However, I wasn't getting that fault code. Hoping to hear some updates about this soon!
#25 ·
Eurodyne 1.5 tuned. Similar limp mode occurrence. Eurodyne was not very helpful and blamed it on my car, not the tune.
Limp mode occurs when going full throttle from 80 mph when traveling up an incline. At about 100mph it goes into limp mode exactly as op described. It has not happened on the highway on relative flat roads, but I don't commonly floor my car on the highway when already going 80mph, so it may.
Here are the codes that I got:
5138: ECM/PCM Processor P0606
15396: Cam Shaft Actuator A Cylinder 2 Range/Performance P11A6
15414: Cam Shaft Actuator B Cylinder 1 Range/Performance P11A4
15418: Cam Shaft Actuator B Cylinder 3 Range/Performance P11AC
#29 ·
Any word back from APR on the reflash availability?
This has happened to me about 5 times now, always at the worst possible time (merging into high speed traffic, or heading up an on-ramp onto a tollway that doesn't have another exit for several miles). I'm about ready to dump APR's stage 1 and go back to stock before it gets me killed... It's a damn shame, my wife's Mk6 GTI has been on APR Stage 1 software for 3 years without a single issue.
#32 ·
The most recent thing I've heard from APR (through my tuner) on December 11 was:
"Justin replied: Benji, Calibration is still working on that revision for the Golf R and S3 cars that are running into EPC issues. They’ve made several changes already and we’re getting there. Thanks, Justin, Solution Provider"
I'm sure the flash update got de-prioritized during the Holiday new product rush, since they actually make money selling those vs developing the re-flash. Here's hoping it will get some priority again now. Lord knows, I am sick and tired of waiting.
#37 ·
I read on another thread (http://forums.vwvortex.com/showthre...40742-APR-Presents-the-North-American-MK7-Golf-R-amp-MK3-S3-ECU-Upgrade!/page39) and checked with my local APR dealer (NGP Racing in Virginia). Apparently APR quietly released an upgraded v2 for the Stage 1 Golf R/S3 tune that I'm told is the long-awaited limp mode fix. I'll be making an appointment for a re-flash as soon as I can. About damned time! I'll let you all know if I learn more (e.g., if it's just the limp mode fix as I read or includes other changes).
#35 ·
Expand all
Collapse all
Offboard Diagnostic Information System
Diagnostic Log(Short)
23.12.2015 19:56
XML_to_HTML_Main.xsl Version: 4.31.2 from 2015-10-27
General Information
RO Number : ---
Log type :
Guided Fault Finding
Log status :
Temporary log
Workshop information
Diagnostic tester serial number :
8c5c54182b608a689f766a313ac80d16
Hardware platform :
VAS 6150B (PanasonicCorporation / CF-52JE2VWVW)
Operating system :
Windows 7
VCI type :
VAS 5054 (113862277)
VCI connection type :
Bluetooth
Communication path :
CAN/K line
Importer number :
444
Dealer/facility number :
08230
Facility ID :
(manual specification)
Contract status :
Authorized dealer
Software versions :
Offboard Diagnostic Information System Service :
Offboard Diagnostic Information System Service Base 3 . 0 . 0
Main feature :
8.0.180
-Additional :
MCD server manufacturer :
Volkswagen AG
MCD server name :
VW-MCD
MCD server version :
310.5.3
MCD server API version :
3.0.0
PDU API manufacturer :
Softing D-PDU API for VCIs
PDU API version :
1.20.34
PDU API API version :
1.20.34
ECF version :
26.2.0 (20151015)
General Testscript API Version :
unknown
API version test script :
4.31.6
Measurement Types :
9.0.4
Installed diagnostic data:
GFF DIDB brand:
V
GFF DIDB version:
2.30.2
GFF DIDB language:
en_US
Base DIDB version:
2015.12.3.AutoGenerated
Base DIDB language:
en_US
Vehicle :
Brand :
Volkswagen
Type :
AU / BE / BX - Golf 2013 > only USA/Canada
Model year :
2016 (G)
Version :
Sedan
Engine code :
all engine identifier codes
License plate :
(ElsaPro is not available)
VIN (automatic) :
WVWUF7AU0GW138185
VIN (manual) :
WVWUF7AU0GW138185
Odometer reading (km) :
4548
ASAM project name :
VW37X
ASAM project version :
31053.0.2143
Diagnostic Session
Start diagnosis:
23.12.2015 19:43
Time required (TU): 29
End of diagnosis: 23.12.2015 19:56
First system test with DTC memory entries
Address : 0022 System name : 22 - All-wheel drive electronics Log versions : UDS/ISOTP ( Ereignisse : 0 )
-Identification:
Hardware part number :
0CQ525130
Part number :
0CQ907554H
Hardware version number :
H52
Software version number :
7083
Production date :
07.08.2015
Coding :
Index
Byte
Value (hex)
Value (bin)
1
$ 1
$ 00
00000000
2
$ 2
$ 01
00000001
Ability to flash :
Unknown
System name :
Haldex4Motion
ASAM base version :
BV_AllWheelContrUDS
ASAM 2D/ODX data set :
EV_AllWheelContrHA1VW37X
ASAM 2D/ODX data set version :
004013
ASAM/ODX control module version being used :
EV_AllWheelContrHA1VW37X_004
Target data container :
v1260x015G0
Version of the target data container :
0000
Equipment code :
00 00 00 00 00 00 00 00 00 00 00 00
System abbreviation :
J492
Address : 0042 System name : 42 - Driver door electronics Log versions : UDS/ISOTP ( Ereignisse : 0 )
-Identification:
5Q0959593B
Part number :
5Q0959593E
020
0041
Production date :
07.09.2015
Coding :
Index
Byte
Value (hex)
Value (bin)
1
$ 1
$ 00
00000000
2
$ 2
$ 3E
00111110
3
$ 3
$ 13
00010011
4
$ 4
$ 20
00100000
5
$ 5
$ 80
10000000
6
$ 6
$ 00
00000000
7
$ 7
$ 04
00000100
8
$ 8
$ 00
00000000
9
$ 9
$ 00
00000000
10
$ A
$ 00
00000000
11
$ B
$ 00
00000000
12
$ C
$ 00
00000000
Ability to flash :
Unknown
System name :
TSG FS
ASAM base version :
BV_DoorElectDriveSideUDS
EV_DCUDriveSideEWMAXKLO
006003
EV_DCUDriveSideEWMAXKLO_006
5G0222v____
0064
Equipment code :
FF FF FF FF FF FF FF FF FF FF FF FF
J386
Address : 0052 System name : 52 - Passenger door electronics Log versions : UDS/ISOTP ( Ereignisse : 0 )
-Identification:
5Q0959592B
Part number :
5Q0959592E
020
0041
Production date :
17.09.2015
Coding :
Index
Byte
Value (hex)
Value (bin)
1
$ 1
$ 00
00000000
2
$ 2
$ 3E
00111110
3
$ 3
$ 13
00010011
4
$ 4
$ 20
00100000
5
$ 5
$ 80
10000000
6
$ 6
$ 00
00000000
7
$ 7
$ 04
00000100
8
$ 8
$ 00
00000000
9
$ 9
$ 00
00000000
10
$ A
$ 80
10000000
11
$ B
$ 00
00000000
12
$ C
$ 00
00000000
Ability to flash :
Unknown
System name :
TSG BFS
ASAM base version :
BV_DoorElectPasseSideUDS
EV_DCUPasseSideEWMAXKLO
006003
EV_DCUPasseSideEWMAXKLO_006
5G0157v____
0060
Equipment code :
J387
Address : 0001 System name : 01 - Engine electronics 1.8–2.0 FSI EU2/EU6 Log versions : UDS/ISOTP ( Ereignisse : 2 )
-Identification:
06K907425E
Part number :
8V0906259H
H13
UM3S
Production date :
18.09.2015
Coding :
Index
Byte
Value (hex)
Value (bin)
1
$ 1
$ 09
00001001
2
$ 2
$ 19
00011001
3
$ 3
$ 00
00000000
4
$ 4
$ 12
00010010
5
$ 5
$ 24
00100100
6
$ 6
$ 26
00100110
7
$ 7
$ 00
00000000
8
$ 8
$ 0E
00001110
9
$ 9
$ 30
00110000
10
$ A
$ 04
00000100
Ability to flash :
Unknown
System name :
2.0l R4 TFSI
ASAM base version :
BV_EnginContrModul1UDS
EV_ECM20TFS0208V0906259H
001003
EV_ECM20TFS0208V0906259H_001
Equipment code :
J623
-DTC memory entries:
DTC memory entry
Number :
P11A600: Cam Shift Actuator "A" Cylinder 2 Range/Performance
Error type 2 :
passive/sporadic
Symptom :
15396
Status :
01101000
-Standard ambient conditions:
Date :
12/19/15
Time :
7:09:45 AM
Mileage (DTC) :
4112
Priority :
2
Frequency counter :
2
Elimination counter / driving cycle :
255
-Expanded ambient conditions:
Engine speed
1491.25
1/min
Normed load value
9.019608
Vehicle speed
108
km/h
Coolant temperature
91
°C
Intake air temperature
2
°C
Ambient air pressure
970
mbar
Voltage terminal 30
14.746
V
Dynamic environmental data
20 96 1D 11 0E 03 16 B6 FF FF 16 9D 00 16 9C 03 16 9E 00 25 16 A1 01 C8 16 A2 03
Unlearning counter according OBD
29
STATE_ENG
PL
CAM_VCP[EX_1]
-0.0078125
CTR_VVL_LIH_DEAC
0.0
CTR_VVL_LIH_ACT
3.0
CTR_VVL_SWI_DC
37.0
T_SWI_VVL_ACR
45.6
ms
NR_CYL_FIRST_VVL_SWI
3.0
DTC memory entry
Number :
P060C00: Internal Control Module Main Processor Performance
Error type 2 :
passive/sporadic
Symptom :
29388
Status :
00100000
Date :
12/19/15
Time :
7:09:41 AM
Mileage (DTC) :
4112
Priority :
2
Frequency counter :
2
255
Engine speed
4767.75
1/min
Normed load value
76.47059
Vehicle speed
130
km/h
Coolant temperature
90
°C
9
°C
990
mbar
Voltage terminal 30
14.609
V
20 96 1C 17 17 92 36 17 18 44 94 17 19 13 FA 17 1A 20 7C 17 1B 19 F6 17 1C 00 00 17 1D 00 00
28
ENVD_0_MON
37430.0
ENVD_1_MON
17556.0
ENVD_2_MON
5114.0
ENVD_3_MON
8316.0
ENVD_4_MON
6646.0
ENVD_5_MON
0.0
ENVD_6_MON
0.0
Address : 0014 System name : 14 - Wheel damping electronics Log versions : UDS/ISOTP ( Ereignisse : 0 )
-Identification:
5Q0907376A
Part number :
5Q0907376A
H17
0120
Production date :
28.09.2015
Coding :
Index
Byte
Value (hex)
Value (bin)
1
$ 1
$ 00
00000000
2
$ 2
$ 00
00000000
3
$ 3
$ 00
00000000
Ability to flash :
Unknown
System name :
DAEMPFUNGS-SG
ASAM base version :
BV_WheelDampeElectUDS
EV_DRCONTITEMIC
001019
EV_DRCONTITEMIC_001
5G0532v____
0044
Equipment code :
J250
Address : 0003 System name : 03 - Brake electronics Log versions : UDS/ISOTP ( Ereignisse : 0 )
-Identification:
3Q0907379F
Part number :
3Q0907379AA
H42
0623
Production date :
14.09.2015
Coding :
Index
Byte
Value (hex)
Value (bin)
1
$ 1
$ 01
00000001
2
$ 2
$ FA
11111010
3
$ 3
$ 6B
01101011
4
$ 4
$ A1
10100001
5
$ 5
$ 54
01010100
6
$ 6
$ 23
00100011
7
$ 7
$ 09
00001001
8
$ 8
$ 74
01110100
9
$ 9
$ 05
00000101
10
$ A
$ 78
01111000
11
$ B
$ 03
00000011
12
$ C
$ 08
00001000
13
$ D
$ 41
01000001
14
$ E
$ C8
11001000
15
$ F
$ 69
01101001
16
$ 10
$ 80
10000000
17
$ 11
$ D6
11010110
18
$ 12
$ 2A
00101010
19
$ 13
$ 90
10010000
20
$ 14
$ A0
10100000
21
$ 15
$ C0
11000000
22
$ 16
$ 82
10000010
23
$ 17
$ 96
10010110
24
$ 18
$ B7
10110111
25
$ 19
$ 00
00000000
26
$ 1A
$ 40
01000000
27
$ 1B
$ 00
00000000
28
$ 1C
$ D4
11010100
29
$ 1D
$ C0
11000000
30
$ 1E
$ 08
00001000
Ability to flash :
Unknown
System name :
ESC
ASAM base version :
BV_Brake1UDS
EV_Brake1UDSContiMK100IPB
034036
EV_Brake1UDSContiMK100IPB_034
Equipment code :
J104
Address : 0044 System name : 44 - Power steering Log versions : UDS/ISOTP ( Ereignisse : 0 )
-Identification:
3Q0909144H
Part number :
3Q0909144J
505
5063
Production date :
02.10.2015
Coding :
Index
Byte
Value (hex)
Value (bin)
1
$ 1
$ 81
10000001
2
$ 2
$ 02
00000010
Ability to flash :
Unknown
System name :
EPS_MQB_ZFLS
ASAM base version :
BV_SteerAssisUDS
EV_SteerAssisMQB
012140
EV_SteerAssisMQB_012
5G0074v____
0984
Equipment code :
J500
Address : 0015 System name : 15 - Airbag Log versions : UDS/ISOTP ( Ereignisse : 0 )
-Identification:
5Q0959655J
Part number :
5Q0959655J
010
0830
Production date :
16.09.2015
Coding :
Index
Byte
Value (hex)
Value (bin)
1
$ 1
$ 8C
10001100
2
$ 2
$ CC
11001100
3
$ 3
$ FC
11111100
4
$ 4
$ 00
00000000
5
$ 5
$ 00
00000000
6
$ 6
$ 00
00000000
7
$ 7
$ 00
00000000
8
$ 8
$ 00
00000000
9
$ 9
$ 50
01010000
10
$ A
$ 00
00000000
11
$ B
$ 00
00000000
12
$ C
$ 1A
00011010
13
$ D
$ C2
11000010
14
$ E
$ 48
01001000
15
$ F
$ 00
00000000
16
$ 10
$ 00
00000000
17
$ 11
$ 00
00000000
18
$ 12
$ 65
01100101
Ability to flash :
Unknown
System name :
AirbagVW20
ASAM base version :
BV_AirbaUDS
EV_AirbaVW20SMEVW37X
002144
EV_AirbaVW20SMEVW37X_002
5G0003V____
0121
Equipment code :
J234
Address : 0055 System name : 55 - Automatic vertical headlight aim control Log versions : UDS/ISOTP ( Ereignisse : 0 )
-Identification:
7P6907357A
Part number :
7P6907357D
H07
0090
Production date :
25.09.2015
Coding :
Index
Byte
Value (hex)
Value (bin)
1
$ 1
$ 02
00000010
2
$ 2
$ 22
00100010
3
$ 3
$ 02
00000010
4
$ 4
$ 00
00000000
5
$ 5
$ 0B
00001011
6
$ 6
$ 00
00000000
7
$ 7
$ 04
00000100
8
$ 8
$ 00
00000000
Ability to flash :
Unknown
System name :
AFS-ECU
ASAM base version :
BV_HeadlRegulUDS
EV_HeadlRegulVWAFSMQB
001120
EV_HeadlRegulVWAFSMQB_001
V03935205NP
0001
Equipment code :
J745
Address : 0075 System name : 75 - Emergency call module & comm. unit Log versions : UDS/ISOTP ( Ereignisse : 1 )
-Identification:
5QE035285A
Part number :
5QE035285A
007
0568
Production date :
16.09.2015
Coding :
Index
Byte
Value (hex)
Value (bin)
1
$ 1
$ 02
00000010
2
$ 2
$ 73
01110011
3
$ 3
$ 00
00000000
4
$ 4
$ 02
00000010
5
$ 5
$ C2
11000010
6
$ 6
$ 82
10000010
7
$ 7
$ 1A
00011010
8
$ 8
$ 01
00000001
9
$ 9
$ 7F
01111111
10
$ A
$ 1E
00011110
11
$ B
$ 06
00000110
12
$ C
$ 02
00000010
13
$ D
$ 00
00000000
14
$ E
$ 00
00000000
Ability to flash :
Unknown
System name :
OCULowMQBUS
ASAM base version :
BV_TelemCommuUnitUDS
EV_OCULowMQB
001006
EV_OCULowMQB_001
V03935221QP
0001
Equipment code :
J949
DTC memory entry
Number :
B149AF0: Mobile Online services Vehicle state report
Error type 2 :
passive/sporadic
Symptom :
13636864
Status :
00001000
Date :
12/10/15
Time :
12:33:54 PM
Mileage (DTC) :
3044
Priority :
7
Frequency counter :
1
148
Address : 0017 System name : 17 - Instrument cluster/immobilizer Log versions : UDS/ISOTP ( Ereignisse : 0 )
-Identification:
5G1920858A
Part number :
5G1920858A
303
6420
Production date :
28.09.2015
Coding :
Index
Byte
Value (hex)
Value (bin)
1
$ 1
$ 0B
00001011
2
$ 2
$ AD
10101101
3
$ 3
$ 08
00001000
4
$ 4
$ 12
00010010
5
$ 5
$ 3B
00111011
6
$ 6
$ 80
10000000
7
$ 7
$ CF
11001111
8
$ 8
$ 05
00000101
9
$ 9
$ 02
00000010
10
$ A
$ 08
00001000
11
$ B
$ 6A
01101010
12
$ C
$ 00
00000000
13
$ D
$ 14
00010100
14
$ E
$ 00
00000000
15
$ F
$ 00
00000000
16
$ 10
$ 00
00000000
17
$ 11
$ 00
00000000
18
$ 12
$ 00
00000000
19
$ 13
$ 00
00000000
20
$ 14
$ 00
00000000
Ability to flash :
Unknown
System name :
KOMBI
ASAM base version :
BV_DashBoardUDS
EV_DashBoardVDDMQBAB
009046
EV_DashBoardVDDMQBAB_009
Equipment code :
J285
Address : 0047 System name : 47 - Sound system Log versions : UDS/ISOTP ( Ereignisse : 0 )
-Identification:
5Q0035456
Part number :
5Q0035456
H20
0130
Production date :
21.07.2015
Coding :
Index
Byte
Value (hex)
Value (bin)
1
$ 1
$ 22
00100010
2
$ 2
$ 00
00000000
3
$ 3
$ 00
00000000
4
$ 4
$ 00
00000000
5
$ 5
$ 00
00000000
6
$ 6
$ AA
10101010
7
$ 7
$ AA
10101010
8
$ 8
$ AA
10101010
9
$ 9
$ 00
00000000
10
$ A
$ 00
00000000
11
$ B
$ 00
00000000
12
$ C
$ 00
00000000
13
$ D
$ 00
00000000
14
$ E
$ 00
00000000
Ability to flash :
Unknown
System name :
MIB2_lite_amp
ASAM base version :
BV_SoundSysteUDS
EV_AMPMst12C1Gen2ALPI
001003
EV_AMPMst12C1Gen2ALPI_001
5G0050v____
2011
Equipment code :
J525
Address : 00B7 System name : B7 - Access/Start system interface Log versions : UDS/ISOTP ( Ereignisse : 0 )
-Identification:
5Q0959435
Part number :
5Q0959435A
021
0604
Production date :
23.09.2015
Coding :
Index
Byte
Value (hex)
Value (bin)
1
$ 1
$ 03
00000011
2
$ 2
$ 0C
00001100
3
$ 3
$ 0C
00001100
Ability to flash :
Unknown
System name :
VWKESSYMQB
ASAM base version :
BV_AccesStartInterUDS
EV_KessyHellaMQBAB
002011
EV_KessyHellaMQBAB_002
V03935197YW
0001
Equipment code :
J518
Address : 0016 System name : 16 - Steering column electronics Log versions : UDS/ISOTP ( Ereignisse : 0 )
-Identification:
5Q0953549E
Part number :
5Q0953507HL
003
0110
Production date :
23.09.2015
Coding :
Index
Byte
Value (hex)
Value (bin)
1
$ 1
$ 04
00000100
2
$ 2
$ 00
00000000
Ability to flash :
Unknown
System name :
Lenks. Modul
ASAM base version :
BV_SteerColumElectUDS
EV_SMLSKLOMQB
017001
EV_SMLSKLOMQB_017
Equipment code :
J527
Address : 0008 System name : 08 - A/C/heating electronics (Climatronic) Log versions : UDS/ISOTP ( Ereignisse : 0 )
-Identification:
5G0907044BD
Part number :
5G0907044BD
H03
1001
Production date :
02.10.2015
Coding :
Index
Byte
Value (hex)
Value (bin)
1
$ 1
$ 00
00000000
2
$ 2
$ 02
00000010
3
$ 3
$ 00
00000000
4
$ 4
$ 04
00000100
5
$ 5
$ 20
00100000
6
$ 6
$ 01
00000001
7
$ 7
$ 00
00000000
8
$ 8
$ 00
00000000
9
$ 9
$ 00
00000000
10
$ A
$ 05
00000101
11
$ B
$ 00
00000000
12
$ C
$ 00
00000000
13
$ D
$ 12
00010010
14
$ E
$ 11
00010001
15
$ F
$ 14
00010100
16
$ 10
$ 02
00000010
Ability to flash :
Unknown
System name :
Climatronic
ASAM base version :
BV_AirCondiUDS
EV_ACClimaBHBVW37X
004131
EV_ACClimaBHBVW37X_004
0000
Equipment code :
J255
Address : 0009 System name : 09 - Electronic central electronics Log versions : UDS/ISOTP ( Ereignisse : 0 )
-Identification:
5Q0937085AF
Part number :
5Q0937085AJ
H24
0175
Production date :
22.09.2015
Coding :
Index
Byte
Value (hex)
Value (bin)
1
$ 1
$ 00
00000000
2
$ 2
$ 01
00000001
3
$ 3
$ 0A
00001010
4
$ 4
$ 46
01000110
5
$ 5
$ C0
11000000
6
$ 6
$ 41
01000001
7
$ 7
$ A2
10100010
8
$ 8
$ E1
11100001
9
$ 9
$ 69
01101001
10
$ A
$ E4
11100100
11
$ B
$ 40
01000000
12
$ C
$ 00
00000000
13
$ D
$ 09
00001001
14
$ E
$ 1C
00011100
15
$ F
$ 07
00000111
16
$ 10
$ 20
00100000
17
$ 11
$ 18
00011000
18
$ 12
$ 00
00000000
19
$ 13
$ 00
00000000
20
$ 14
$ 00
00000000
21
$ 15
$ 00
00000000
22
$ 16
$ 00
00000000
23
$ 17
$ 00
00000000
24
$ 18
$ 00
00000000
25
$ 19
$ 00
00000000
26
$ 1A
$ 00
00000000
27
$ 1B
$ 00
00000000
28
$ 1C
$ 00
00000000
29
$ 1D
$ 00
00000000
30
$ 1E
$ 00
00000000
Ability to flash :
Unknown
System name :
BCM MQBAB HNA
ASAM base version :
BV_CentrElectUDS
EV_BCMMQB
015001
EV_BCMMQB_015
V03935222AW
0001
Equipment code :
J519
Address : 0019 System name : 19 - Diagnostic interface for data bus Log versions : UDS/ISOTP ( Ereignisse : 0 )
-Identification:
5Q0907530F
Part number :
5Q0907530AF
128
1223
Production date :
05.09.2015
Coding :
Index
Byte
Value (hex)
Value (bin)
1
$ 1
$ 01
00000001
2
$ 2
$ 01
00000001
3
$ 3
$ 00
00000000
4
$ 4
$ 08
00001000
5
$ 5
$ 30
00110000
6
$ 6
$ 08
00001000
7
$ 7
$ 59
01011001
8
$ 8
$ 00
00000000
9
$ 9
$ FB
11111011
10
$ A
$ 00
00000000
11
$ B
$ 02
00000010
12
$ C
$ 2A
00101010
13
$ D
$ 88
10001000
14
$ E
$ 0F
00001111
15
$ F
$ 00
00000000
16
$ 10
$ 00
00000000
17
$ 11
$ 00
00000000
18
$ 12
$ 01
00000001
19
$ 13
$ 05
00000101
20
$ 14
$ 00
00000000
21
$ 15
$ 00
00000000
22
$ 16
$ 00
00000000
23
$ 17
$ 00
00000000
24
$ 18
$ 00
00000000
25
$ 19
$ 00
00000000
26
$ 1A
$ 00
00000000
27
$ 1B
$ 00
00000000
28
$ 1C
$ 00
00000000
29
$ 1D
$ 00
00000000
30
$ 1E
$ 00
00000000
Ability to flash :
Unknown
System name :
GW MQB High
ASAM base version :
BV_GatewUDS
EV_GatewLear
013020
EV_GatewLear_013
V03935223TH
0001
Equipment code :
J533
Address : 00A9 System name : A9 - Structure-borne sound actuator Log versions : UDS/ISOTP ( Ereignisse : 0 )
-Identification:
4H0907159A
Part number :
5G0907159D
H07
0001
Production date :
12.08.2015
Coding :
Index
Byte
Value (hex)
Value (bin)
1
$ 1
$ 00
00000000
2
$ 2
$ 00
00000000
3
$ 3
$ 00
00000000
Ability to flash :
Unknown
System name :
SAS-GEN 2
ASAM base version :
BV_ActuaForStrucBorneSoundUDS
EV_SoundActuaGen2AU64X
003010
EV_SoundActuaGen2AU64X_003
Equipment code :
J869
Address : 002B System name : 2B - Steering column lock Log versions : UDS/ISOTP ( Ereignisse : 0 )
-Identification:
5Q0905861A
Part number :
5Q0905861A
H01
0120
Production date :
24.09.2015
Coding :
Index
Byte
Value (hex)
Value (bin)
1
$ 1
$ 55
01010101
2
$ 2
$ 00
00000000
3
$ 3
$ 00
00000000
4
$ 4
$ 00
00000000
5
$ 5
$ 00
00000000
6
$ 6
$ 00
00000000
7
$ 7
$ 00
00000000
8
$ 8
$ 00
00000000
Ability to flash :
Unknown
System name :
ELV-MQBA
ASAM base version :
BV_SteerColumLockiUDS
EV_ELVMarquMQB
004111
EV_ELVMarquMQB_004
Equipment code :
J764
Address : 005F System name : 5F - Information electronics 1 (Standard) Log versions : UDS/ISOTP ( Ereignisse : 0 )
-Identification:
3Q0035876
Part number :
3Q0035876
H25
0245
Production date :
26.08.2015
Coding :
Index
Byte
Value (hex)
Value (bin)
1
$ 1
$ 02
00000010
2
$ 2
$ 73
01110011
3
$ 3
$ 00
00000000
4
$ 4
$ 02
00000010
5
$ 5
$ 00
00000000
6
$ 6
$ 00
00000000
7
$ 7
$ 00
00000000
8
$ 8
$ 00
00000000
9
$ 9
$ 51
01010001
10
$ A
$ 22
00100010
11
$ B
$ 00
00000000
12
$ C
$ 02
00000010
13
$ D
$ 00
00000000
14
$ E
$ 18
00011000
15
$ F
$ 08
00001000
16
$ 10
$ 00
00000000
17
$ 11
$ 1F
00011111
18
$ 12
$ 02
00000010
19
$ 13
$ 07
00000111
20
$ 14
$ F4
11110100
21
$ 15
$ 01
00000001
22
$ 16
$ 20
00100000
23
$ 17
$ 01
00000001
24
$ 18
$ 05
00000101
25
$ 19
$ C6
11000110
Ability to flash :
Unknown
System name :
MU-S-NS-US
ASAM base version :
BV_InforContrUnit1UDS
EV_MUStd4CTSAT
001022
EV_MUStd4CTSAT_001
V03935223SB
0001
Equipment code :
J794
Additional system tests with DTC memory entries
System test no. : 2
Address : 0001 System name : 01 - Engine electronics 1.8–2.0 FSI EU2/EU6 Log versions : UDS/ISOTP ( Ereignisse : 0 )
-Identification:
06K907425E
Part number :
8V0906259H
H13
UM3S
Production date :
18.09.2015
Coding :
Index
Byte
Value (hex)
Value (bin)
1
$ 1
$ 09
00001001
2
$ 2
$ 19
00011001
3
$ 3
$ 00
00000000
4
$ 4
$ 12
00010010
5
$ 5
$ 24
00100100
6
$ 6
$ 26
00100110
7
$ 7
$ 00
00000000
8
$ 8
$ 0E
00001110
9
$ 9
$ 30
00110000
10
$ A
$ 04
00000100
Ability to flash :
Unknown
System name :
2.0l R4 TFSI
ASAM base version :
001003
Equipment code :
J623
-Steps performed
No. Form Result
1
Diagnosis is being prepared
OK
2
Check radio connection
OK
3
Create results log
OK
4
Detecting VIN
OK
5
Analyzing VIN
OK
6
Check vehicle identification
OK
7
Checking for DoIP vehicle project
OK
8
Establishing vehicle
OK
9
Use K line adapter
OK
10
Log on for group system access
OK
11
Set brand design
OK
12
Check contract status
OK
13
Detect vehicle data
OK
14
Identify and select order data
OK
15
Check vehicle project
OK
16
Control module communication configuration
OK
17
Detect control module list
OK
18
Check for quick entrance
OK
19
Check for availability of LT3 vehicle
OK
20
Check for CAN diagnosis
OK
21
Evaluate Gateway components list
OK
22
OK
23
Read control modules
OK
24
OK
25
Check the Gateway communication.
OK
26
Pause quick entrance
OK
27
Perform traversal test
OK
28
Identify control modules again
OK
29
Check for fixed installation control modules
OK
30
Check control module versions
OK
31
Create knowledge base
OK
32
Index documents
OK
33
Perform start module
OK
34
Test plan is being calculated
OK
35
Determine special functions
OK
36
Set diagnostic log type
OK
37
Reset user setting Avoid DoIP communication.
OK
38
Check for vehicle change
OK
39
Test version J623_X_1_0313_11_X_X_MSG_Nockensteller_00011
OK
Origin: System plan
40
Evaluate suspicions
OK
41
Check vehicle and ignition status
OK
42
OK
43
Check DTC memory
OK
44
Update test plan
OK
45
Prepare secondary session
OK
46
OK
47
Open components list
OK
48
Enter secondary session
OK
49
Synchronize control module lists
OK
50
Control module OBD: DTC memory 0075 - Telematics Communication Unit
OK
#44 ·
EPC FaultS 2016 Golf-R Mark 7: APR Stage 1
EPC Fault: (Limp mode = loss of power)
10/24/2016 between 4:30 & 5:15pm
Traveling about 96 mph - location 33 miles out of Melbourne on I95:
• Traveling at ~80mph when Accelerator died . I think there was some vibration….
• Power steering ok
• AC OK
• EPC error on console. Light on solid
• Water temp at 200F. No oil temp warning light or else.
• Cruised to stop off shoulder in grass
• Smelled something burning/burnt but could have been the grass
• ~20 minutes later engine started on first attempt. Made calls for towing but cancelled when car started.
• No EPC light
• Drove remaining 33 miles tentatively while eventually up to 65 mph without any issues
• Visual Inspection looks fine.
• Car appears to be normal now
VW Dealer - Can't reproduce problem. Pertinent codes are P11A600 (Cam Shift Actuator Cyl# 2) and P060C00 (Internal Control Module Main Processor)
APR Support - Please have your ECU updated to the newer v2.3 Stage 1 file. This will prevent that error from occurring again
