What's the point of coolant running through the throttle body?
67K views 40 replies 16 participants last post by  Honda Odyssey
#1 ·
What are the pro's and con's of removing the coolant lines from the throttle body and bypassing them?
#3 ·
FV-QR
Quote, originally posted by Nick2002GLI »
It is used for heating the throttle body. Keeping the throttle body warm prevents moisture from freezing during the winter. So I guess this helps in Canada... Last time I removed my throttle body I bypassed it.
#6 ·
I don't think so. What do you mean by "behave well"? Mine ran fine in Yosemite earlier this year at 18 degrees F. These engines do seem tempermental about outside temp though, it feels like I lose 20hp every time it is above 78F outside. It drops colder at night and suddenly I have more horsepower.
#9 ·
Re: (jefswat)
This is an interesting topic. My father told me not to mess with it because ice cold potentially form in there over time when driving in cold conditions.
But I only travel north once a year and live in HELL (southern Ga.) so I definitely bypassed mine for now, and have encountered zero problems.
Oh yeah and amen on the running like a dog when its warm out. Oh but when its cold out.....
#14 ·
Re: (jediv6)
Quote, originally posted by jediv6 »
Mine feels the same, on warm days seems lacking in power, but on cold days, goes like a rocket, whats that all about?
cold air is more dense than hot air. the more air/fuel (correct ratio) you can cram into the cylinder the more power you make. that's how forced induction works. forcing air into the motor. and getting too hot increases knock and detonation, and the ignition timing will retard and you lose power. with no knock or detonation you won't pull timing. (intake temp sensor reading too warm can pull timing too) hence using a intercooler and water/methanol injection on a forced induction car.
how to make power 101
oh, and delete the coolant lines. that was a factory mistake.
Modified by VEE-DUBBER at 12:35 AM 7-13-2009
#15 ·
They are not critical to coolant flow, they are much to small to effect the main cooling system.
You should NOT just delete them if it EVER gets near freezing where you live or drive as your throttle valve could ice shut. All modern vehicles run coolant through the throttle body, VW is no different. This is no "factory mistake". There is always a reason behind the madness.
This engine seems more temperature temperamental than any other car I have ever driven. Small changes in temperature drastically changes the way the engine behaves. Typical VW quirk
Modified by apstguy at 2:08 AM 7-13-2009
#41 ·
Well if u know that coolant have charge and it's also reverse in polarity by the way that's why some of the parts related to the throttle body rust its because rust it come from oxigen and oxigen its - charge atract to positive charge in the coolant since that I mentioned in first want coolant cross the negative field that runs the block , became coolant became positive, now why its that happening its because the cold air its more boost end u see more power if you delete that coolant from the throttle body now will atract to + air and its 73 % nitrogen that's why cold air its more power the more cold it gets more power the more hot I gets loss power why its that . When its cold contract/vx hot expend and when expend loses pressure because of heat and heat its be cause oxigen , that's why when u forging metal the furnace need lots oxigen into to get hot, we don't want to the engine to be hot , will lose power, cold its the way
#18 ·
When the cat starts to go bad the O2 codes will randomly go away and then come back. My light turned off for several months, but a couple weeks ago has been on pretty consistently again. I don't see any reason why it would CAUSE the light to go off. False association here.
Modified by apstguy at 10:26 PM 7-13-2009
#22 ·
Re: (apstguy)
HaD the code on for 2 years. Did te tb bypass today. No code..... Over the two years I had th code. My car never showed any symptoms or signs of a bad sensor or a bad cat conv. It runs smooth..... Great gas mileage.... Everytime I would put in a fuel treatmeant back in the day the light would turn off... Turn back on a moth later....
#23 ·
My car shows no symptoms of a bad cat but the constant O2 codes. A failing cat will show no symptoms but failing an emissions test or the O2 codes you are currently getting. Every once and a while the might smell like rotten eggs when failing, but more modern cars don't do that often.
Also, if the rear oxygen sensor goes bad, there will be no telling except for the MIL. The rear sensor only tells the ECU that the cat is working. and controls nothing on the car.
Your code will be back, just a matter of time.
Have you ever performed oxygen sensor aging tests? How was your last emissions test (if you have them where you live)?
Modified by apstguy at 12:01 AM 7-14-2009
