Re: Stock Radio Mess... "Safe Mode" (BugShow)
VW's code system gives you three tries to enter the correct code, and if you still get it wrong, the radio will lock up for an hour. In this case, leave the radio on for an hour. Then you can re-enter the code.
To enter the code, hold down the MODE and SCAN buttons until "1000" appears on the display, then let go. Use the preset buttons 1, 2, 3, and 4 to enter the first through fourth digits of the code. (The first digit of the code will always be "0" or "1". If the first digit is "0", it is left blank on the radio display, so a code of "0570" will appear as " 570"). When you have the code entered, hold down MODE and SCAN until "SAFE" appears on the display. Let go, and if you entered the correct code, the radio will start to play. If not, "SAFE" will blink and either you will get another chance to enter the code or the radio will lock up for an hour, depending on how many of the three tries you have already used.
